hesitation
Old Jul 14, 2006 | 12:15 PM
car86cars's Avatar
hesitation
Hesitation
The car hesitate on take off. but codes 44 &33 are coming up. If I cut it off and try to start it up again it want. If I put my foot on the gas it will. code 44 comes up for lean exhaust my injector are ohm out at 16.5 fuel pressure is at 38 psi @ idle 44 psi whith key on tps is set at .54 and timming 6 degree i am lost at this piont
If I hit the gas fast it's stall. if i ground the test port under the dash it will start after about 6 times What do you think it could be? stock 305 tpi
Old Jul 14, 2006 | 12:35 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
my techer at school says that hesitation is usually cause by clogged or lazy injectors. but either way it is usually some sort of injector problem(so he says).
Old Jul 14, 2006 | 02:13 PM
car86cars's Avatar
when it hesitation the fuel pressure is at about 46 psi does it worse under load in gear don't know what to try next
Old Jul 14, 2006 | 04:55 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
lean exhaust ? Makes me think you either have a vaccuum leak , exhaust manifold leak , or a sticky IAC valve.
Old Jul 14, 2006 | 06:56 PM
car86cars's Avatar
i did see that the exhaust manifold is leaking buy the o2 sensor will this cause a stalling problem? i clean the iac today
Old Jul 17, 2006 | 04:01 PM
car86cars's Avatar
i changed the tps and the iac and nothing going to try o2 sensor next
Old Jul 18, 2006 | 06:22 PM
car86cars's Avatar
new o2 new iac new tps new auto zone mass air flow fix exhaust leak what to try next
Old Aug 2, 2006 | 06:24 PM
car86cars's Avatar
well took car to the shop and they are saying that the injector might be bad ohm out at 16.5 to 16.8 and alldata say 16.35 max
Fanatic1074
Oct 3, 2022 05:57 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
