starting problem i think its the injectors??
Old Jul 19, 2006 | 10:12 PM
powered69ing's Avatar
Car: 87 iroc-z z28 camaro
Engine: 5.7 tuned port injection
Transmission: automatic
i have an 87 iroc with a 305 tpi my car will not start randomly and when it doesnt start i have plenty of fuel pressure and i have a spark from the coil it just keeps turning over but wont fire up i talked to a friend and he thinks the computer is bad but i dont know could you help
Old Jul 19, 2006 | 10:36 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
run a scan and see if your getting a code from ur computer
Old Jul 20, 2006 | 12:03 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
MOst likely not the computer, no starts don't usually yeild a code, but worth a try to check it out.
'87 is a MAF, next time, try unpluggng the electrical aconnector on the underside of the MAF and see if it fires?
May also be the cold start valve, but I don't have too much experience with them.
Is the no start when cold motor? Or anytime?
Old Jul 20, 2006 | 12:29 AM
qube's Avatar
Car: 1988 Pontiac GTA
When it does fire does it run OK?
Could be a duff temp sensor making the ECU think the engine is hot when it isn't thus the mixture will be too lean to get the engine to start.
Could be a leaky injector causing the engine to flood.
Could be a bad ECU reading the sensors wrong.
I'd put the car on some diagnostics so you can see what the ECU thinks is happening when the engine is starting up.
M.
Old Jul 20, 2006 | 01:51 AM
Individual's Avatar
My 350 has troubles starting to somtimes. I had my mechanic look at it and he thinks its the injectors flooding the engine. My motor runs rough for a few moments, you have to keep it at 2000 RPM and it will clear.
Old Jul 20, 2006 | 08:01 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Do you have fuel? Are the injectors opening when the engine is turning over?
Old Jul 21, 2006 | 12:50 AM
my car runs fine when its on and it only stops starting when its been running for awhile then i come back to it in a couple of hours and it starts fine
Old Jul 21, 2006 | 01:24 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
does the starter even work in this NO start condition ? If not I would lean towards heat soak of the starter .
Old Jul 21, 2006 | 08:49 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Yea, does the starter turn over the engine when you say NO START. Does it crank?
Old Jul 21, 2006 | 11:57 PM
yes it turns over fine just doesnt fire up and i have fuel pressure and i have a spark from the coil
Old Jul 23, 2006 | 11:19 PM
jwenn89GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.45 9 Bolt
I had this same exact problem. Check the resistance of your injectors. Most of mine were way low. Somebody on here said that it will overheat a driver in the ecm and not allow the injectors to fire and restart once you turn it off. I replaced my injectors and have been fine ever since.
92camaroJoe
Jul 29, 2023 07:57 PM
bryan623
Mar 22, 2021 06:43 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
