85 5.0 T.P.I. CODE34
Old Aug 8, 2006 | 10:38 PM
firebry's Avatar
Car: 88 formula
Engine: 305 tpi
Axle/Gears: posi 3.23
When I fist start car for the day engine light comes on. After car is warmed up and started later light is off. Then as car reaches proper operating temp engine light comes back on and I lose idle, erratic shifting, over all performance. The error code from the ALDL shows code34 maf sensor.
Does anyone have any ideas of what else could cause this error, and how to test the maf sensor? I can't find any visual problems.
Old Aug 8, 2006 | 10:40 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
you can get an ohm reading on it somehow.... and blow air through it at the sametime.... i think they are pretty cheap.... just don't buy autozone crap.... they worry about selling toys and not parts....
Old Aug 10, 2006 | 09:53 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
They are very expensive. I think about 160 for an autozone brand and upwards of 350-400 for an AC Delco unit. It could be the Maf, Maf power relay, or the Maf burnoff relay. Get yourself a TPI swapper guide book and it shows you step by step on chasing down the problem through various pictures and diagrams.
Old Aug 10, 2006 | 10:48 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
look at my thread (maf +02), vader has a wiring diagram, Test the output when idling etc
hope helps
Old Aug 11, 2006 | 12:00 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Cross your fingers it's the maf on an '85. You don't want to replace the little box (MAS module) under the pass side kick. WAY more than a MAF... IF you can find one (unless something has changed lately).
Now, that said, IIRC the 85's had a problem with false MAF codes and one of the things was to get an updated PROM... hold on...
The updated prom chip should have a silver sticker on it with HLM 3800 on it. If not, you probably need a chip (IIRC ~$50).
The diagram, and MAF itslef, is different on an '85 than an '87.
Old Aug 11, 2006 | 12:04 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
woops, sorry didnt realize you had an 85, Sorry if i confused you
Old Aug 11, 2006 | 03:58 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
my code
i know when i got the mass air sensor code, i changed it 3 times in two months because it kept saying it was bad. then i did a tune up and found out my plugs and wires were bad and i havent seen the code since i did that just putting my two cents in
Old Aug 11, 2006 | 08:16 PM
firebry's Avatar
Car: 88 formula
Engine: 305 tpi
I there also does'nt seem to be maf burnoff relay,it should be by my fuel pump relay and it's not there. Also there is no other wires or connctors laying around .I have looked at varies wirring diagrams they show one should be there unless they are for another year.
Old Aug 11, 2006 | 08:26 PM
firebry's Avatar
Car: 88 formula
Engine: 305 tpi
Thanks for the info, I'm going to have a look at those items. Parts up here are almost impossiable to find especialy electronic parts that are actualy the right part number.
Old Aug 11, 2006 | 11:14 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
No, it (relay) should not be by your fuel pump relay. It does not exists on that car as such. It is part of the MAS under the pass. side kick.
If you are hurting for parts, convert to a SD system. The ecms are relatively abundant in a few other gm models and there are instructions on line and some members who have done it.
1992Z28!
Nov 19, 2015 07:33 AM
sammy52401
Nov 11, 2015 07:20 PM
steimel94
Sep 23, 2015 12:48 AM
89bird2.8
Sep 22, 2015 05:28 PM
steimel94
Sep 20, 2015 12:46 PM
