timing is way off
Old Aug 13, 2006 | 09:03 PM
Syn's Avatar
Syn
Car: 1989 Formula Ws6
Engine: 305 tpi
Transmission: 5speed
timing is way off
so i just put my car back together after doing a lim gasket and it starts but it is lacking all its power and blows lots of black smoke out the tails when trying to florr it sso of course the timing is off, but the thing for ref down by the balancer isn't there so idk what to do
i have a digital timing light if that helps also whats the est plug look like?
Old Aug 13, 2006 | 09:25 PM
calobs87irocz's Avatar
Car: 87 Iroc Z, 70 & 71 Camaros, 79 Z-28
Engine: 350TPI, 350, 355, 355
Transmission: 700R4, TH350, TH350, TH350
Axle/Gears: BW3.27, 4.10, 3.73, don't know yet
The EST is a tan with black stripe 1 way connector in the vicinity of the heater blower/ ac. It sticks out of a 1" diameter piece of convolute.
Old Aug 13, 2006 | 10:02 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
It sounds like it is running to rich.
Old Aug 13, 2006 | 11:02 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Try setting the timing the correct way with the EST connector unplugged :-)
If that doesnt help.
Set the engine to #1 TDC, install distrib pointing to #1, line up reluctor points to the points on the outside of the reluctor.
Should net u 6 degrees or very clost to it before u even fire it provide u find TDC correctly and index the distrib to #1 cylinder.
later
Jeremy
Old Aug 13, 2006 | 11:42 PM
Syn's Avatar
Syn
Engine: 305 tpi
later
Jeremy
idk what any of that is or means beside the #1 cyclinder at top dead center
its my first dizzy car i've had nothing but dis until last year
but my engine is missing that thing on the motor where i know what degrees its at
Old Aug 14, 2006 | 08:32 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
make sure your hooking the lead that goes to your spark plugs to the #1 plug.
But makes no difference if you dont have that tag that tells you your degees.
Almost have to do it by ear now.
Old Aug 14, 2006 | 02:48 PM
Syn's Avatar
Syn
Engine: 305 tpi
well i can't get the bitch even started today i move the dizzy just a tad and now no start doesn't matter where i turn it, i got it to start once and idle at like 300rpms but i couldn't get the idle to smooth out
i'm pissed!
Old Aug 14, 2006 | 03:42 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
its hard without those timing marks. My car ran, but it was way too far advanced. I moved it back to 8 degrees. It helps if you have someone there to help you keep the car at a steady RPM. I had to color my timing mark with a yellow marker so I could see it. It doesnt take much to bump the timing off. A 1/4" could mean a couple degrees. If you havent done it, Take out the #1 plug and get it to top dead center and start all over. At least that will give you a starting place.
Old Aug 15, 2006 | 03:46 AM
Syn's Avatar
Syn
Engine: 305 tpi
great thanks, i feel like a total dip not knowing what to do.
i'll give her a shot tomorrow thanks again for the advice
Old Aug 15, 2006 | 04:31 AM
jethawk's Avatar
Car: 1991 Firebird Formula WS6
Engine: LB9
Axle/Gears: 3.42's
i dunno if this is going to help you but i took a pic of my timing mark and maybe you can print it out and kinda estimate the angle/spot where your timing mark should go
Old Aug 20, 2006 | 04:10 AM
Syn's Avatar
Syn
Engine: 305 tpi
a lil update i got it, and i think its on the money and then some cause i can floor it in first and it does a burnout like it used to
but it feels like its got alot more power!
it pulls alot harder from 3k+ now it used to basically fall on its face now its sweet i put 93 in it just incase it was too advanced or something-not sure if higher octane helps with pinging?
i got some shorty headers too so those to replace the manifolds and the 2in exhuats i should have a huge gain prolly
Old Aug 21, 2006 | 12:34 AM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
Did you check behind the water pump for the timing indicator?
Old Aug 21, 2006 | 05:16 PM
Syn's Avatar
Syn
Engine: 305 tpi
yeah i looked all over, even my buddy came by and showed me where his was.
no a prob tho since its fixed
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
