best chip for tpi
Old Aug 22, 2006 | 10:33 PM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
best chip for tpi
i know someone is gonna bust me for not burning my own chips but whatever. I just want to know who sells the best chips for tpi (custom ones i hope). And does anyone run a TPIS chip, their level 2 chip sounds perfect for my current bolt ons.
Old Aug 22, 2006 | 10:37 PM
s10irocspikes's Avatar
Car: 86 IROC
Engine: 350 Miniram
what do you have done to your car so far?
Old Aug 23, 2006 | 10:29 AM
FormulaL98's Avatar
mods so far are march underdrives, afpr, slp cold air, and a tpis air foil. and other than the tpis wires that is whats included in the tpis fast pak, which is what the level 2 chip is for. so far with those mods i've run a best of 14.28 (not bad for a mostly stock tpi car) with a 8.9 1/8 mile time.
Old Aug 23, 2006 | 06:38 PM
Mark 89Formula's Avatar
I know this is not the answer you want to hear, but save your money. The off the shelf aftermarket PROMs aren't worth it. I've looked at the TPI proms from four different vendors that retailed from $100 to over $400 and it was sad how little was changed. A set of headers and a cat back should put you right into the 13s with the stock PROM.
Old Aug 23, 2006 | 06:59 PM
wackytower's Avatar
Car: 1985 Trans Am
Engine: Superramed 406
Axle/Gears: 10 bolt 3:73
Sent you a PM
Old Aug 23, 2006 | 08:29 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Originally Posted by wackytower
Sent you a PM
Ditto
Old Aug 23, 2006 | 08:53 PM
TRICK_Z28's Avatar
well, i am new to the tpi side of the f body, i have an 82 z that i am puting tpi onto. now i knew that you could burn your owne e prom for hondas and imports but dident know about it for the domestic. i would love to know were i could finde out more
Old Aug 24, 2006 | 02:00 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
TRICK_Z28, read the stickies here,
https://www.thirdgen.org/forums/diy-prom/
they have pretty much everything you need to know.
bamaboy0323
Sep 3, 2015 06:07 AM
NBrehm
Aug 25, 2015 11:49 PM
bdads
Aug 24, 2015 06:01 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
