throttle body
Old Aug 25, 2006 | 01:07 PM
Iroc_man's Avatar
Car: 87 Iroc
Axle/Gears: stock posi
throttle body
if i get a 52 or 58 mm throttle body, is it ok to put it in without porting the plenum right away, or will it run like **** untill the plenum is ported?
Old Aug 25, 2006 | 03:44 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
You won't ever need a bigger throttle body on a 305 TPI, all you'll do is cost yourself throttle response. Spend the money and time porting and siamesing the plenum, porting the base, and install a bigger cam (around 440 to 480 lift and keep it over 220 duration and 112 lsa). You can get this done for the price of a larger TB and it will help you tremendously.
Old Aug 25, 2006 | 05:00 PM
Iroc_man's Avatar
Car: 87 Iroc
no i mean for when i convert to a 350 or 383.
Old Aug 25, 2006 | 07:16 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
even still the 52mm tb is all you need. but as for your question. yes it will help a very small amount, but port the penilum as soon as you can. this site as a tech article on porting it yourself.
Old Aug 25, 2006 | 08:48 PM
zeppelin5000's Avatar
Car: 1991 GTA Trans Am
Engine: 355 TPI
Transmission: 700R-4
Yeah, 52mm is good enough. Many people think going to a bigger 58mm throttle body on a 350 or 383 will help more but it will only rob the engine. 58mm throttle bodies are for bigger engines with much more horsepower.
Old Aug 25, 2006 | 10:43 PM
Iroc_man's Avatar
Car: 87 Iroc
oh ok, so 52mm is probably the max on a 383 then?
Old Aug 26, 2006 | 09:15 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
onless you build a stupidly bad azz 383. then yes a 52mmtb is all you will need,and like said before on a lesser setup the 58 will actualy hurt you.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
