BAD SURGING PROBLEM HELP!!!!
Old Aug 26, 2006 | 11:42 AM
TS87GTA's Avatar
Car: 1987 GTA
Engine: 5.7 TPI
Distributor pickup! is this the culprit
OK i have a 1987 Pontiac GTA 5.7l tpi. It wants to surge when either in town or out on highway going about 55-65. when i first bought the car it surged about 600 rpms, it has a new tps, new MAF, new plugs, new wires, fuel system cleaner added also have added tranny additive and now it only surges about 200 rpms and was placed on computer and its not showing anything. Also when i stop at a light it fells like its pulling, and when cruising aroun it like kicks when it surges. it is getting really annoying but i dont know what it is. What do u all think. there are no vaccum leaks either it ONLY does it from 1300-2000 rpms
Any help would be much appreciated as this is my only vehicle.
Old Aug 26, 2006 | 04:30 PM
TS87GTA's Avatar
Car: 1987 GTA
Engine: 5.7 TPI
could it be the torque conveter or trannsmission
any info is useful
Old Aug 27, 2006 | 10:28 AM
TS87GTA's Avatar
Car: 1987 GTA
Engine: 5.7 TPI
Bump
Old Aug 27, 2006 | 04:30 PM
roc309's Avatar
well i had the same problem it was a pick up coil in the distributor.might be your answer
Old Aug 27, 2006 | 07:23 PM
TS87GTA's Avatar
Car: 1987 GTA
Engine: 5.7 TPI
anyone happen to know how to change these or how much they are
Old Aug 27, 2006 | 07:24 PM
TS87GTA's Avatar
Car: 1987 GTA
Engine: 5.7 TPI
Does 12 bucks sound right through GMpartsdirect.com
Old Aug 27, 2006 | 08:49 PM
roc309's Avatar
yeah sounds right, you have to pull the dis, and take is part to put that thing in it , not excatly sure how to do it sorry
Old Aug 27, 2006 | 09:12 PM
TS87GTA's Avatar
Car: 1987 GTA
Engine: 5.7 TPI
would this being bad make it surge at idle b/c mine ONLY does it from 1300-2000 rpms that all more or less it good
what about the egr could this be a problem can i disconnect it and not run it at all
But wouldnt it throw a code if egr was bad? NEED HELP
Old Aug 29, 2006 | 06:28 PM
TS87GTA's Avatar
Car: 1987 GTA
Engine: 5.7 TPI
bump
bamaboy0323
Sep 3, 2015 06:07 AM
Bryan F
Aug 18, 2015 02:28 PM
jbd1969
Aug 17, 2015 07:06 PM
