what cam?
Old Aug 27, 2006 | 02:31 PM
Iroc_man's Avatar
Car: 87 Iroc
Axle/Gears: stock posi
what cam?
hey all, i got the crappy stock cam in my 87 Iroc 305, what size cam do i need to really boost performance? would this work?
Summit Cam and Lifter Kits: SUM-K1102 - summitracing.com
or do i need something different? i want a good performance cam that will really boost performance. is there any at summitracing.com i could get? any help would be appreciated.
Old Aug 27, 2006 | 05:38 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
Since your car is an 87 that means it came factory with the hydraulic roller camshaft/valvetrain so essentially that particular cam will not be compatible. These are much more expensive (close to 300 brand new)!!Depending on how extreme you are wanting to get with your car i would check out the crane or comp computer compatible camshafts they will give you a description for what they think the power range is. Also since you have a stock tpi setup dont look to make power above 4500 rpms. remember this when looking at your cam
Old Aug 27, 2006 | 08:46 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
i like my cam....
Old Aug 28, 2006 | 07:55 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I have a 1987 Trans Am with the 305 TPI. I just installed the Crane cam 104224.
Some people know it as the Powermax 2032.
Ive had the car for 1 day so far. I love the way it sounds. I never really beat on it yet. I'm letting it break in a bit befor I really get on it. Remember to change the springs. And while your in there, it wouldn't hurt to change out those valve seals also. But for 1st hand experiance.....I like this one.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
