Will this work?
Old Sep 22, 2006 | 11:31 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Will this work?
I am considering buying a crate engine from Jeg's/Blueprint. It's a 383 Vortec SB. My concern is, how well will this work with TPI. I was going to go LTRs and 52mm TB, Big Mouth/ported base. I know the main concern here is the camshaft, and I admit I don't know much about cams and what will work really well with TPI. I've read some of the info here but I want to get opinions from those much more knowledgeable than me.
Here are the engine specs:
JEGS High Performance - Blueprint Engines 383ci SB-Chevy 405HP / 440TQ
Old Sep 23, 2006 | 08:53 AM
Demon355's Avatar
If you are using the LTR's/52mm and Big mouth, the cam should be alright. The TPI LTR setup can take a few extra rpms, I'm using the same setup.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
