IROC Takes 5 mins to start after sitting overnight
Old Oct 1, 2006 | 06:02 PM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
I've had this problem for years with my car and have never been able to figure out the problem. When my car sits overnight and I go to go to work in the morning sometimes it will take 5-10 minutes to start, depending on how much of a hurry I'm in it seems. After it sitting at work all day long, untouched, it always starts right up. It's been sitting for 25 hours right now, I just now went out and it started up on the first try. Could this be enviromental with the high humidity South Florida mornings when there's lots of dew on the car, etc? About a year back I installed a Fuel Pressure Gague to try and diagnose the problem. I have it attatched to my fuel rail and I have it sitting at the bottom of my windshield. The fuel pump always delivers adequate pressure when it kicks on, but it does leak down overnight, could it be a problem with fuel leaking into one or some of the cylinders and flooding the engine? My cold start injector is still installed but I don't know what it does exactly, nevermind how to test if it's working or not.
Justin
Old Oct 1, 2006 | 06:06 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Does it not fire at all? Does it chug and stall? When I had leaky injectors, it took 2-3 tries to start, and would chug until it cleaned itself out.
Old Oct 1, 2006 | 08:35 PM
IROCWPB's Avatar
Engine: 383ci TPI
Axle/Gears: stock
I'm not sure what a chug would sound like. It seems like every other time of the day it fires right up as soon as I hit the starter. As for it firing, I believe it is because sometimes when I'm trying to get it started, it tries, and while trying, kicks the starter out.
Old Oct 4, 2006 | 07:24 PM
IROCWPB's Avatar
Engine: 383ci TPI
Axle/Gears: stock
anyone have any other suggestions? is there any way to test the fuel injectors (leaking, spray pattern, not opening) at home?
Old Oct 5, 2006 | 05:38 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
You need to get a fuel pressure tester, which can be found at Autozone, for like $40. It directly screws into the fuel port on your fail rail and all you have to do is start your car and then shut it off. If the psi drops to 0 quickly you have leaky injectors. If not then move on the trouble shooting process.
Old Oct 5, 2006 | 05:19 PM
IROCWPB's Avatar
Engine: 383ci TPI
Axle/Gears: stock
I said in my initial post that I have a fuel pressure gague installed, which I installed over a year ago to try and diagnose this problem. The pressure doesn't drop right away but will drop to zero overnight. What's my next step to figure this out?
Old Oct 5, 2006 | 08:42 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
Mine did the same thing, and it was a non/working cold start injector.
Old Oct 7, 2006 | 11:15 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
If it takes more than a couple of hours than your injectors are fine.
Old Oct 22, 2006 | 08:28 PM
MedVader's Avatar
Car: 90 Formula hardtop
Engine: 5.0 TPI
sounds like a leaking fpr. The diaphram is letting gas into the intake through the vacuum line.
Run the car. Then pull the vacuum line off the intake manifold and look/smell for gasoline.
Old Oct 22, 2006 | 10:58 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Very strange. My car fires off instantly after sitting overnight.
92camaroJoe
Jul 29, 2023 07:57 PM
backtothe80s
Sep 5, 2015 12:39 AM
jharrison5
Aug 19, 2015 05:53 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
