weird idle issues still
Old Oct 5, 2006 | 03:05 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
well my car has had a surge since i bought it so i set minimum idle and cleaned and adjusted iac and it still has a surge im thinking i should adjust tps since its the only thing i havent done. But i dont kno what to use as a jumper wire to connect the connector and sensor together also i dont get how something that is bolted on volts could change. also i noticed when driving my car the voltage surges too and when my voltage goes down so does my idle then the voltage goes back up and so does my idle.
Old Oct 6, 2006 | 01:44 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
voltage regualtor on the alternator. I was gonig to say MAF buroff relay untill you said the voltage drops and the idle changes , etc.
Old Oct 11, 2006 | 07:10 AM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
tps was set at .60 volts now its back to .54 volts still surges i guess the next step is the voltage regulator.
Old Mar 27, 2007 | 06:36 PM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
Re: weird idle issues still
How would a voltage regulator make the car idle up and down im having this same exact problem so ill deffinatly check but how? The fuel pump gettin its power cut off and on?
Because my car surgest and my volts sure perfectly with the engine just like the post said
Old Mar 27, 2007 | 08:09 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
if voltage moves in and out all your sensors can be affected.
Old Mar 27, 2007 | 08:44 PM
Car: 89 Iroc
Engine: 5.7 TPI
ohh yea thats what i was gussing well i went to autozone for their free check and the guy said my charging system was fine but im going to check it myself tommorw in autoshop to verifie... MY problem is the same as your with the rpm and the volts surging at the same rate... did you ever find you solution... I cant stand it anymore it surges from 500-900 and it dies if i leve it in drive for more then a couple deconds at idle...
Old Mar 27, 2007 | 08:47 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
nope i adjusted in changed all sensors complete tune up everything still would surge but it only surged sometimes and only like 750 to 850 small surging
Old Mar 27, 2007 | 09:08 PM
Dave87IROCZ's Avatar
check your fuel pressure if its jumping your fuel pump is probably bad or the regulator. My car was doing the same thing. Your voltage will fluctuate because the alternator puts out more volts at higher rpms.
Old Mar 27, 2007 | 09:33 PM
Car: 89 Iroc
Engine: 5.7 TPI
i check nad it was a steady 40 psi but i need to check again when its surging...
Also whe ni unplug the o2 i hav e no change and i dont even get a code with it unplugeed
also it runs perfect for about 7 mins when first started in the morning then after that it starts surging... so its when it get warmed up
Old Mar 27, 2007 | 11:54 PM
It sounds like the o2 to me.
Old Mar 28, 2007 | 12:01 AM
Car: 89 Iroc
Engine: 5.7 TPI
Yea ill buy a new one tommorw how do i check the wire going to the o2? to verifie that im gettin signal from ecu or to ecu or a referemnce signal?
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mike_c
Aug 27, 2015 04:32 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
