Which brand of wires is better?
Car: 87 firebird
Meaning spark plug wires on a 91 355 tpi camaro z28. Has edelbrock tes headers and y pipe, k&N filters, cutout,airfoil and hooker catback.
Thinking of either MSD or Accel. Which is better for application? Will get cap and rotor of the brand also.
thanks
thanks
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Which brand of wires is better?
I used to like Accel until I pulled my wires off and found a couple of 'em burned through.
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
MSD's are the best as far as resistance. However I had an issue with them not fitting on the tower correctly and I had to trim the boot on the Distributor cap end to get them to seat properly. Therefore when I replaced them I put in Accel wires and I had no issues with them.
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I have a set of Taylor spark wires, which are cut to length on one end. This way you can run the spark wires to suit your specific needs, like keeping them away from hot header pipes. I ran mine up to the top of the valve covers, then down the lengthof the covers to the dizzy.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Car: 1987 Iroc-z Convertible
Delphi with federal mogal sleeves and a D.U.I. dist setup. best I have found to date and with the wires I had one laying on my header pipe for about an hr and it never burned through. this was the stuff that was on my old 87, still have it for my vert. EXPENSIVE though
Street Lethal
Apr 30, 2019 12:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
