holley adjustable fpr issue
Old Oct 6, 2006 | 02:09 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
my stock fuel pressure with the stock regulator was always around 40psi...... i just installed the holley adjustable regulator, and if i tighten the screw on it all the way down, my pressure goes up to 40 psi.... if i loosen it, my pressure lowers.
very simple question, that probably has a complicated answer, WHY won't my pressure go past 40psi?!?!!?
things it simply can NOT be:
1)fuel pump has been changed numerous times, pressure has never been more than 40 psi, my pump is fine.
2)fuel filter has been changed twice since i've had the car, i've never seen the pressure past 40 psi, my filter is fine.
Old Oct 6, 2006 | 04:01 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Under what conditions are you measuring? Engine running? Vaccum line off?
Old Oct 6, 2006 | 06:15 PM
bigchief's Avatar
engine running, off and vaccum line off the pressure pretty much stays the same......... when i take off the vaccum line the pressure goes up maybe 3-5 psi
Old Oct 6, 2006 | 06:21 PM
ROCITUP's Avatar
IS IT A STOCK PUMP.......I JUST INSTALLED A WALBRO AND IT WORKED FINE WITH MY HOME-MADE AFPR.47 PSI
Old Oct 6, 2006 | 06:23 PM
bigchief's Avatar
my fuel pump is a holley 255 lph pump that i bought from summit
Old Oct 7, 2006 | 07:54 AM
ator's Avatar
Car: 92 Firebird Formula
Transmission: 700 R4, 3.73 rear
Perhaps your AFPR is bad
Old Oct 8, 2006 | 12:48 PM
bigchief's Avatar
i dont think it is because before i installed this one, i installed crane's and i had the same issue.... i ended up breaking the adjustment screw on it because i didnt think it was completely tightened lol.... thats why i got the holley one
Old Oct 9, 2006 | 10:15 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
the first one I bought from summit I noticed a small tear in the diaphram
I sent it back before putting it on my car, the box was all battered and beat up
I hope they did not send you that one.
Old Oct 9, 2006 | 12:02 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
thats weird....I cant get my holley past 40 psi either on a stock pump. I had it dialed to 48 psi brand new, then I went to turn it down and it jumped down very quickly to 30 psi....It was so hard to get it to clockwise and I could not get past 40. When i close off the fuel return line the car dies. I thought this was a sign of a bad fpr
Now my car isnt starting. Not sure if its the pump or fpr or relay
Old Oct 9, 2006 | 12:54 PM
Abubaca's Avatar
Is the pressure guage ok?
Old Oct 9, 2006 | 05:52 PM
bigchief's Avatar
yeah i'm pretty sure the guage is perfectly fine, i put another guage on their when i had the crane on it just to make sure it wasn't messed up..... i'm beginning to think i have like a crink in my lines somewhere :-/
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86IROC112
Aug 17, 2015 02:00 PM
wayshegoes
Aug 17, 2015 12:00 PM
