Go fast ideas, please.
Old Oct 9, 2006 | 09:37 PM
carguy502's Avatar
Car: 1969 Nova
Engine: LT4 Hot Cam L98
Axle/Gears: 3.42 8.5" 10 bolt
Ok, I run 13.70s in my nearly stock (air foil, 1 5/8 block huggers, dual Flowmaster 2.5, and a home brewed CAI) 1990 Corvette L98 with a T5 and 3.42 gears in my Nova. I want to run faster (low 13s/ high 12s) and was looking for mods that might not affect my drivability too much. I was thinking AS&M runners, ported plenum, 1.6 RR, and maybe a different manifold. Do I need more mods like valvesprings/cam to go this fast?I don't want to kill mileage too much, so any help would be cool.
Old Oct 9, 2006 | 10:42 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
i think the runners, base, and RR, should be good for low 13s. cam and ported heads might get you 12s.
Old Oct 10, 2006 | 12:32 AM
Demon355's Avatar
The AS&M runners, ported/aftermarket base & plenum, AFPR, 1.6 rockers should get you close to that I would think. Changing cam would need bigger valve springs yes and it's always good to change out the guides when you do this. Do you have the aluminum head?
Old Oct 10, 2006 | 12:46 AM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
1.6 RR's will help. They add a bit more overlap, you will notice the difference since you have headers to take advantage of the overlap.
An edelbrock large tube base and AS&M large tube runners will really liven up your TPI after 3500 rpms. Though they are rather costly added up.
If you do get a cam, make sure its a single pattern cam. The corvette heads have D-shape ports which flow very well. So they don't need a cam with extra exhaust duration as a cruch.
Porting the heads is also an option.
Old Oct 10, 2006 | 12:29 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Nitrous won't effect mileage, and will net you 12's.
Old Oct 12, 2006 | 12:16 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Thats the easy way out though
Basically, mostly anything engine related that is not a cam will keep your mileage the same, give or take a mpg. If you were going to do the intake, I would take the time to do some porting on those heads, you can really open them up, and it would compliment the intake very nicely. Take advantage of a custom burned chip from somewhere like pcmforless.com to further help match your computer to what has been done so far. You can expect at LEAST 10HP there, and some guys have gotten over 20HP.
Old Oct 12, 2006 | 12:32 PM
Drac0nic's Avatar
If you pull the intake off to change it you're already half way through a cam swap or if you do a cam swap you've already pulled the intake off so you almost may as well do as a pair. I'd expect decent gains with a home ported base and a ported plenum, even without the runners (although I'd expect a good bit more with all 3) then a cam and a chip to take advantage of it all you'd really be moving!
Old Oct 12, 2006 | 09:26 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I did his chip. It rules.
Old Oct 14, 2006 | 01:42 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I was hoping to be the first to say Nitrous but I missed it so let me second that notion. It doesn't eat anything when you're not using it, and it's addictive like a drug when you do use it.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Jetmeck
Sep 4, 2015 12:29 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
