Still running rich as Hell....
Subscribe
Oct 23, 2006 | 08:14 PM
I made a thread on this a month ago and here is the deal. My car is running very rich... Here is what I have done.
Checked resistance on all injectors... all in the range of 17-17.5 Ohms..
Leak checked injectors... holds pressure for hours.
Coil has been replaced.
Timing is at 7*
IAC has been replaced
TPS has been replaced
I have a 355, running 19lb injectors.... So basically I have a 305 setup on a 355... prom is stock too...
need some advice guys.
Reply 0
Oct 23, 2006 | 08:41 PM
question, why do you think its rich? black smoke? smells funny? something else?
you said stock PROM, stock for a 305 or 350?
Reply 0
Oct 23, 2006 | 08:45 PM
i had the same problem until a got a stock 350prom and some 23lb accel injectors. i went thought the hole 305 to 350 switch too. so i know your pain. whats funny is that at an idol you run rich and at upper rpms you end up running lean . iam still working all the bugs out with the switch. i still need the 350esc module and knock.
good luck,
mike
Reply 0
Oct 23, 2006 | 09:08 PM
I am running rich, because I can smell it... and flames come out if I punch it..
I have a stock 305 prom on a 355.
Id hate to change the injectors but looks like I have no choice... or do i?
Reply 0
Oct 23, 2006 | 09:13 PM
Quote: I am running rich, because I can smell it... and flames come out if I punch it..
no choice. you need that prom changed too. see about hooking it up to a meter and seeing what the air/fuel ratio is. and btw with no cat youll get flames and smoke any way. having no cat is also why you smell fumes so badly.
Reply 0
Oct 23, 2006 | 09:19 PM
yeah sounds like you should be running lean everywhere based on teh fact that you have a 305 chip and injectors on a 355. L98 350's had 22lbs.
hows your O2 sensor? make sure thats workin good. No cat will make it smell bad anyway tho. i guess you could check the spark plugs to see if they have fuel on them and smell really strong of gas.
else the simplest thing to do is just go 22lb injectors and 350 prom. or keep the 19's and do a adj pressure regulator and crank that sucker up. i'd do the 22's tho.
Reply 0
Oct 23, 2006 | 09:26 PM
also just another thought but make sure the fuel pressure reg is good. i had one that the diaphragm broke and gas was running through the line into the intake. made it run real rich. couldn't figure it out either
Reply 0
Oct 23, 2006 | 09:48 PM
good point, that very well could be the problem
Reply 0
Oct 23, 2006 | 10:19 PM
I have an AFPR what psi is stock... I am not asking what is best for my setup because that is a variable... but what should a stock 350 have... with 22 lb injectors... what should I use on a stock 350 with 19lb injectors?
Reply 0
Oct 23, 2006 | 11:10 PM
stock is 42.5 i believe... so 42-43 will work
Reply 0
Oct 25, 2006 | 05:15 PM
if you still running the tpi intake
if you still running the tpi intake the flutes in the exhaust maniflod that control exhaust going into your intake for cold idle sould be frozen up or not working it sounds like your o2 sensor is getting outside air you might have a leak in your exhaust system b4 the o2 sensor that will trick the sensor into thinking your running lean so it will tell the comp to richin it up
Reply 0
Oct 25, 2006 | 07:26 PM
umm... I have headers... and the o2 sensor is just fine.
Reply 0
Oct 30, 2006 | 09:16 AM
Check one of the vacuum lines to see if there's good vacuum. A stuck open EGR valve could the problem. Also check O2 sensor, MAP sensor, Coolant temp. sensor and IAT. Check spark plugs and wires. That could also be the problem.
Reply 0
Subscribe
