fuel question
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
fuel question
thinking of upgradeing my injectors.. i want to get a new fuel pump, regulator and injectors.
first question.. if i put the accel 30lb injectors... will it run to rich
second, will i need a new fuel runner and lines?
lastly will this increase power if i time it properly?
Car: 1989 Pontiac trans-am
Engine: building a 400
don't waist you money on 30# injectors if you got a stock motor. It doesn't need them and you will do more harm than good buy installing them. If you get an adj fuel pressure regulator you can increase the flow of your injectors. If you really want to do something with them take them out and have them cleaned it will cost about 15.00 each but its better than putting 30# injectos in.
ok, thats good information, can i cleen them myself? and would it be a good idea to get a new pump as well? i was wondering if you guys could tell me a few specs on the fuel system so i understand more. i plan to get about 400 hp out of the L98 so when is a good time to start to change fuel equipment
IMHO the only reasons you should be putting in 30s is if you're gonna do a stout N/A motor or forced induction later on. By stout I mean more cubes, big runner heads and so on. You'll definitely need a chip or aftermarket ECM, and as stated you won't gain any power from injectors directly unless your car is running like crap.
If you decide to replace your injectors, do yourself a favor and stay away from Accel injectors. Their quality is as bad if not worse than the stock Multecs. Ford SVO replacement injectors are good quality and price, and work great with our tpi systems as long as you get the same lbs. per hour as you have now.
what does a new ecm do for your car.. i was wondering that ebfore. i ehrd you got to order a chip that is spacific to your car or something...anyone got more info on that?
Re: fuel question
84z96L31vortec
Aug 20, 2017 12:16 AM
