I need to know what size bolts for runners.
Old Oct 25, 2006 | 10:17 AM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
What size bolts are used for the runners on the plenem and lower base. I need to know how many of each size. Thread size and length. Thanks guys.
Old Oct 26, 2006 | 07:34 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
Does anybody know?
Old Oct 26, 2006 | 12:21 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
They are a standard 8mm bolt. Lenghts vary and I think there are 10 bolts for each side.
I believe that TPI Parts sells a complete set.
Old Oct 26, 2006 | 01:05 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
Can someone tell me how long they are and how many of each length I will need.
Old Oct 30, 2006 | 12:50 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
bump
Old Nov 3, 2006 | 09:15 PM
74vette's Avatar
Car: 74 and 87 convert vettes
Engine: 383 /350
Transmission: 400 / 4+3
Axle/Gears: stock
I'll give you the answer tomorrow, gotta dig the set I bought out. I got them from a guy in WA for $50, chrome allen heads, I couldnt get them cheaper at the HW store. There are 2 or 3 sizes (legnths) I have a set of stockers I'd give you if you paid the postage.
Old Nov 3, 2006 | 10:05 PM
Bigseth's Avatar
Car: 86 Iroc 383 carb, 97 T/A WS6
The runner bolts are M8X1.5 is the size. I dont quite remember the lengths tho. I know the upper bolts are 2- 30mm long and 2- 40mm long per side if I remember correctly. Hope that helps some
Seth
Old Nov 4, 2006 | 01:34 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I just did the base on my 87 TPI car and they were NOT metric. I had to get a set of standard allen head bolts to get it to mount. The runner bolts were metric, I just took a stock bolt and found a nut that fit it, then found the right length regular hex head bolts to replace the stockers.
Old Nov 4, 2006 | 07:06 AM
Vader's Avatar
The bolts holding the intake base to the heads are 3/8-16,various lengths.
tom1985
Apr 19, 2016 07:55 AM
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
knight72
Aug 10, 2015 09:32 PM
