AFR 180 or 195 heads?
Old Nov 3, 2006 | 07:48 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Im building a new 350 for my 92 Camaro and I have a ZZ4 short block, TPIS ZZ9 Cam, TPIS big mouth base and the Accel Superram. I been back and forth with head choice between Edelbrock, Trickflow or AFR. I decided after alot of reading that AFR would be the best choice, but now here is the final choice. 180 cc or the 195 cc street eliminator head?
Old Nov 3, 2006 | 09:02 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
195
Old Nov 3, 2006 | 09:12 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Thats what I thought as well but I wanted to see what others thought would be better. Thanks
Old Nov 3, 2006 | 10:36 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Latest design 195.
Old Nov 3, 2006 | 10:45 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'd go 180's with that setup,
Old Nov 3, 2006 | 11:10 PM
Guest
Guest
Posts: n/a
Definitely 195's.
Old Nov 3, 2006 | 11:23 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
thats something of a small cam for a super ram. that cam will make power below 6000rpms witch tells me that the 180cc would be better. so you dont lose any low end power. but to be honest with a super ram id look for a bigger cam than that. the zz409 or a bigger cam would do that super ram good. the zz9 cam is for a stock style TPI not a super ram.
so in short, if you stay with that cam 180cc if you get a bigger cam 195cc.
180cc will be good for a 350 to 6000 rpms, any more rpms than that and the 195s will get it done.
Old Nov 3, 2006 | 11:30 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Another vote for the 180's. I've got a pair of comp ported 180's waiting to go on a similar setup, and they are really overlooked and I think under rated. They are great heads.
Old Nov 4, 2006 | 07:17 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
so 3 for 180 and 3 for 195
Old Nov 4, 2006 | 08:04 AM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Say's it all, in my opinion
Old Nov 4, 2006 | 08:46 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Yeah Im reading TPIS insider hints book and about 6000 is all I would get out of that cam. So the 180cc heads would be best.
Old Nov 4, 2006 | 08:57 AM
Slayre's Avatar
As you can see the 180's would probaly be optimum for your setup, however the 195's allow you to grow. Changing cams would be alot less hassle than heads, cheaper to.
Old Nov 4, 2006 | 09:16 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Honestly, the new AFR 180cc heads flow better than the old 195s up to at least .500 lift (with the base port job) so it's not really that simple anymore.
I went with the 180cc heads, and I'm still sitting the fence between a 355, 383, supercharged, N/A, etc. etc but I do know I'm not building a high-revving high RPM screamer.
Old Nov 4, 2006 | 09:47 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
I dont plan on changing my set up in the furture as of now but you never know what might happen. If I go with the 180 cc it will be better now but if I decide in the future to go with the miniram and the ZZ409 cam the 195 heads will be better, but I probably will not want to change anything for a long time.
Old Nov 4, 2006 | 11:40 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Low end torque loss between the 2 would probably be minimal, if any. If you cam, gear, and tune it correctly you will not miss any of it. It's all about a matched combo! 180s would be great for a LTR setup. With a Superram you gotta let it breathe. If you want to outrun LS1s on the highway 195s are a better choice. I used to have the old AFR 190s and wish I went slightly bigger (like 195 or 200cc).
Old Nov 4, 2006 | 11:46 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Basically thats want I want. I want a good streetable car that will get me throught emissions and still have plenty of power to be able to hold its own.
Honeslty my goal is to make as close to 350hp as I can. If this set up makes more thats great.
Old Nov 4, 2006 | 12:00 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
there are two factors here that tell me that you should get the 180cc. the fact that you have a 350ci motor and your cam. now like i said before IF you did go with a bigger cam the 195cc would be your best bet. i will also add, that the diff between the two will be minumal, like iroczz3 stated, i mean were not talking about 10hp its more like 5hp peak hp. but head size will affect your power curv drasticly. with a 195 head and TOO small of a motor you will lose lots of bottom end and break even up top. just remeber anything to 6k =180cc,and >6k = 195cc on your 350.
Old Nov 4, 2006 | 01:03 PM
BadSS's Avatar
There is a slight velocity difference between the 180 and 195s, but considering the 195s have much more velocity than a set of stock 165cc heads,,,, it's hard not to go with the flow difference and the extra potential of the 195s. I know you didn't ask,,, but you would be better off going with more duration on the intake and less duration on the split,, along with .530 or so lift on the intake side on the cam - using the SuperRam and the 195s. You would see no difference in idle or cruise response and could pick up 25 horses or so,,, on top of the difference you would see between the 180s and 195s.
Old Nov 4, 2006 | 02:57 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Thanks everyone for there responses.
Old Nov 4, 2006 | 08:30 PM
Car: 1989 GTA
Engine: 369 TPI
By the way I'm running 195cc Trickflow heads with the exact same cam you want to run. At least for the moment. I have a new combination waiting to be installed. Horsepower and specs are in my signature.
By the way the new AFR 195 heads are pretty darn good. Run as much compression as you can.
92projectcamaro
Jan 18, 2016 08:00 AM
z28guy134
Sep 1, 2015 11:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
