350 TPI whats this connector/sensor??
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
I just picked up the engine the other day.. and either on the take out or haul to the place i brought it to it got damaged.. (or it got burned up from before)
here are 2 pics of it.. any help would be great and where i can get the new connector!
ImageShack - Hosting :: connectorkz5.jpg
ImageShack - Hosting :: connector1jb4.jpg
Car: 1991 Camaro RS
maybe you both are right... but for some reason i think it actually might be the knock sensor.... not 100% sure yet ill let you guys know when i find out
thanks
thanks
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Knock sensor and fan temp switch are the same style connector. Fan switch is in the the passengers side head and the knock sensor is in the block on the same side.
Car: 1991 Camaro RS
can the connector be bought at any auto part store? or do i have to find it online somewhere?
Car: 1983 G20 Chevy
Transmission: 4L60
Orielley's Auto Parts, cost about $6.80. They pulled out the catalog and I found it for the knock sensor. I am using it along with a cooling fan switch on my 3.1 to control the electric fan, through a relay of couse. I'll dig around in the garage to see if I can find the box with the part number on it. It is a Borg Warner part. It is hanging from the rear of the passenger side head, attached to the fan switch.
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Car: 1983 G20 Chevy
Transmission: 4L60
No, it is a little trick I have found over time, I smear it with my finger around the gap, it helps prevent small oil leaks that might otherwise occur.
