how much hp will the stock injectors support?
Old Nov 7, 2006 | 04:17 PM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
sorry if this one is beaten to death, but the search wouldnt work for me right now. ive got an L98 with the 22# injectors (i think???) i sent a rod out the oil pan, so now im planning on a 383 with an LT4 hot cam and 1.6rr. as for now the heads will be stock, no porting or anything done to them. i dont really have any idea how much power ill be making, but i figured someone might know.
also, is there a better choice for a cam in the 383 than the LT4 hotcam?
Old Nov 13, 2006 | 01:03 AM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
Here's a link for all the math regarding injectors.
http://www.rceng.com/technical.htm
Old Nov 13, 2006 | 05:09 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
So is it safe to say that stock 22's will not even let a 370hp motor run period?
Old Nov 13, 2006 | 10:31 PM
Transmission: TH350
That's not really correct either. They will make it run and run good up to the point that the engine needs more fuel than they can smoothly deliver. I've been told that injectors will even work at 100% duty cycle but only for very short periods of time. I don't really subscribe to that theory but it sounds reasonable.
Its like my wallet. It works good up until I'm broke, then there's nothing left.
Old Nov 14, 2006 | 01:28 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Dont trust injectors at 100% or close to duty cycle.
Above the 80+ % mark most get unstable and the pintle action is uncontrolled resulting in both lean and rich conditions depending on the exact situation encountered.
A good rule of thumb is to figure an injector capable of supporting your combo at roughly 80% duty cycle to definitely give u a margin for error.
later
Jeremy
Old Nov 15, 2006 | 04:20 AM
Transmission: TH350
Absolutely right. 80% duty cycle is the number to use.
Here's a what not to do story about a guy I know... He thinks that more is better in all things. He always overestimates his capabilities (both car and personal). anyway... He went out and bought some huge injectors. I can't remember exaclty what they were but they were big. He thought that the mild cam he had installed (by a mechanic) was going to net 400 hp . So when he put the injectors in (himself) his car ran like $$$t. Go figure.
Too big is also not a good thing. The moral of the story is be honest with your hp calculations/estimates and use the math formulas.
Old Nov 15, 2006 | 09:14 AM
HD4mula's Avatar
OK, so would it be too bad to try to run a 330RWHP 350ci car with the stock 22 pounders?
Old Nov 15, 2006 | 09:43 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I've hit 300 rwhp with stock ones before.
Old Nov 15, 2006 | 02:15 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
I would recomend 24# on that engine, a little too much fuel is ok, but not enough fuel is terrible from a performance standpoint.
Old Nov 16, 2006 | 12:42 AM
Transmission: TH350
If you go to the link posted above then scroll to the bottom of the page there is a fill in the blank injector calculator. Play with the numbers to find some reasonable ranges and you'll get a good idea of what hp to expect from you injectors.
Old Nov 16, 2006 | 01:43 AM
Car: 89 Formula
Engine: 5.7 TPI
ROFL, i like that, thanks for the link atomic!
Old Nov 16, 2006 | 08:20 AM
HD4mula's Avatar
Yeah. It gave me 30lbs based on the BSFC from my dyno data. But I don't think I need that big. My engine did 236hp/344tq to the wheels before. After adding AFR Eliminator 180s (milled to 10:1), fully ported plenum, AS&M runners, Ported Edelbrock base, 1.6 roler rockers and CC XFI 268 cam I think I can hit 300+ RWHP so I need to know now that the intake is still disassembled. I wasn't planning on that spending.
Old Nov 16, 2006 | 09:02 AM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
You can play around with fuel pressures to get more out of smaller injectors. It would be a good idea to get an adjustable fuel regulator to bump up the pressure. Im not sure whats the highest pressure you can run safely though. I have been able to get my regulator up to 60 psi but have never run it that high. I did it just to see if it could be done. Maybe someone here might know the highest you can run the pressure and whats a safe limit.
Old Nov 16, 2006 | 02:45 PM
HD4mula's Avatar
I have a FPR. I run it at 43psi (under load) in my 350. I can try to get the dought for some Ford or Bosh injectors but this project is way over budget. But if I need them now is the time. To get the fuel rail out I need to remove the valve covers so it is a big PITA if I have to go with this later.
Old Nov 16, 2006 | 07:27 PM
Transmission: TH350
I got injectors from http://www.fiveomotorsport.com The guy's name is Bruce.
The overbudget thing is tough but it is always better to do it right the first time rather than do it again later.
One more thought here. Math doesn't lie! If you do the calculations correctly, trust the math! That is why I like to play with the numbers a little bit... go with 80% duty cycle and 0.5 BSFC to get a conservative number, then go with 95% to find the limit. Some of it depends on how you plan on driving. If you'll only hit max rpm once in a blue moon then go with a touch small. I doubt this is the case though. We who have power like to use it.
Old Nov 16, 2006 | 10:20 PM
Stevo's Avatar
Car: Pair of 92 Z28s
thanks for the info guys
Terrell351
Jun 13, 2021 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
z28_AJ
Aug 27, 2015 08:59 PM
ezobens
Aug 19, 2015 10:29 PM
