TPI CONVERSION
Old Nov 7, 2006 | 05:13 PM
Superior Styles's Avatar
Car: 1986 CHEVY CAMARO IROC-Z
Engine: Twin Turbo 383 (1190hp 1249Tq)
Transmission: 1000 rated T56 6 speed manual
Axle/Gears: 3.73 Posi & mini spool & 28 spline
TPI CONVERSION
WHAT IS IT THAT I NEED TO START A TBI COVERSION?
WHAT ENGINE BLOCK?
WHAT CAR SHOULD I GET THE TPI FROM?
DOES ANY TPI DONT BRING A MASS AIRFLOW SENSOR?
WHAT ENGINE SHOULD I NOT GET?
LET ME KNOW EVERYTHING I NEED
Old Nov 8, 2006 | 08:06 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Any tpi will work, but might as well get a 350 tpi for the little extra it may cost. Hawksthirdgenparts.com sells em. They are gaurenteed to be in good running condition. You can get the complete engine, and wiring harness from them. You will also need the proper ecm and prom, and a good MPFI fuel pump. Other than that you are good to go. Unless this is a v6 car, then the trans you currently have will bolt right up. There is no specific year you need, and I think that 85-89 were MAF cars. Then they went to speed density, or MAP sensors. If you need more info, ill help you out the best i can.
Old Nov 8, 2006 | 08:34 PM
THANK U
Old Nov 9, 2006 | 11:17 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
don't go with a 1985 TPI ... the ECM is limited .
lt1z350
Aug 28, 2015 05:57 AM
theurge
Aug 21, 2015 12:46 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
