NEW SUMMIT THROTTLE BODY QUESTIONS
Old Nov 12, 2006 | 10:51 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Has anyone used one of the Summit throttle bodies? Also, do they have all the mounts for IAC, TPS, and all the vacumn line and coolant hookups like the OEM? I need a new throttle body as mine is so corroded the water manifold bolts are going to break when I attempt to take them out(have been soaking body for two days in Let-Go)and also the main butterfly shaft is worn out. I have a stone stock motot and simply want a replacement that I can just bolt on, set specs. and go. Need responses ASAP as the car is down and I need to get it running. Thanks, Badman
Old Nov 12, 2006 | 11:04 AM
MARO-MAN's Avatar
Car: I've had 4 thrid gens!!
Engine: Someday again I will have another!!
How much are they from Summit? That is the aftermarket one right? Waste of money. I would just get a bone stock TB off of ebay(I could only find one on there though ) or other board member. Save you tons of cash, but may take longer to get. -Nick.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
