Please Help! Idles at 1500 RPM!
Old Nov 19, 2006 | 09:25 PM
bking43101's Avatar
My 85 IROC idles at 1450-1500 rpm about 99% of the time and the other 1% it tries to stall out unless I hold the throttle. Maybe a vacuum leak? Where would be the best place to start to fix it? This is my daily driver and my gas mileage really sucks right now. Any help would be appreciated.
Old Nov 20, 2006 | 01:37 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Vacuum leak would be my first guess.
TPI or IAC issue would prolly be my second guess.
THOUROUGH VISUAL INSPECTION OFTEN RESULTS IN FINDING THE CULPRIT WITHOUT FURTHER DRAMA.
That being said, check out all your basics and work from easiest to test/inspect to hardest.
Busted vacuum lines, broken gasket edges etc can all be examined without tearing the car apart.
let us know what u find and give us info as you go.
later
Jeremy
Old Nov 20, 2006 | 08:06 AM
bking43101's Avatar
I will certainly keep you posted. Hopefully it's not anything too serious or expensive.
Old Nov 20, 2006 | 07:15 PM
bking43101's Avatar
I just bought a new IAC valve which I will install tomorrow. Hopefully that will fix it. I couldn't see anything like a blown gasket or anything like that so we'll have to see what happens.
Old Nov 20, 2006 | 07:53 PM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
hey mine did that for a wile to but did not stall. i bet it wont be the iac, and you can cleen those. anywho i checked all the lines, nothing. i gave up. i put a new iac valce in. tps sensor etc. i spent about 200 bucks on it. it was still running like **** and high idling. i took it to my shop and he reset my comp and cleened my intake manfild. runs so good now. give that a try.
Old Nov 20, 2006 | 09:21 PM
bking43101's Avatar
I'll try that, although I'm still going to replace the IAC since I already bought it. I'm not sure what you ment by "cleaned the intake manifold". What exactly did your guy do? Do I need to pull it off the car? I know these are weak questions but I want to be sure that I don't do more harm than good.
Old Nov 21, 2006 | 09:25 AM
dave-92gta's Avatar
yea i jsut cleened the whole air intake system. after 14 years, and 70 thousand miles later, it gets dierty. i jsut cleened out the plenum, runners and as best i could intake maifold. i jsut took the runners and plenum off. i probably got about 5-7 hp of lost hp back and better throttle responce. just get some TB cleener and use that. that way its burnable in your engine. thats what i did, worked better.
Old Nov 21, 2006 | 09:26 AM
bking43101's Avatar
Fortunately the IAC was the problem so everything is running fine now. Thank you to everyone who offered advice.
Old Nov 21, 2006 | 11:38 AM
dave-92gta's Avatar
try cleening your plenum and components out anyway. gives you abck some extra gas milage and power
Old Nov 21, 2006 | 01:25 PM
bking43101's Avatar
That will be the next thing I do. Thank you for the advice.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
forstral
Aug 19, 2015 03:20 PM
