location of fuel pressure regulator???
Old Nov 20, 2006 | 03:55 PM
bigtom88transam's Avatar
Car: 88 trans am, and 06 focus DOHC
Engine: 305 tpi
Axle/Gears: 4.56 screaming pave eating :-)
anyone happen to know the location of the fuel pressure regulator on an 88 305 tpi motor?????
Old Nov 21, 2006 | 02:49 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Its under the plenum towards rear of engine.
If you look from the pass rear of the plenum you can see it underneath, follow the vaccum line from the pass rear of the plenum.
later
Jeremy
Old Nov 21, 2006 | 06:13 AM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
Axle/Gears: 3.27 Borg Warner 9bolt
Yea what 3.8TransAM said. It is right in front of the dist. it is held down by torx bolts and its probably black
Old Nov 21, 2006 | 11:26 AM
Engine: 305 tpi
have to take tpi manifold off ??
Old Nov 21, 2006 | 11:41 AM
3.8TransAM's Avatar
Just the plenum.
Undo all the bolts and hit it with a rubber mallet, should come out.
later
Jeremy
Old Nov 21, 2006 | 12:08 PM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
What are u tryin to do with regulator?
Old Nov 21, 2006 | 12:48 PM
Vader's Avatar
Originally Posted by 3.8TransAM
Just the plenum.
later
Jeremy
How crude! The real finessè method would be to loosen all the upper runner fasteners, wrap a bit of detonation cord around all the gasketed joints, stand back about 50 yards, and yell "Fire in the Hole!" as you "release" the plenum.
Okay - Maybe the mallet is a better idea.
Old Nov 21, 2006 | 03:51 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
BBK regulator
Hope you are not considering buying a BBK fuel pressure regulator. The adjustment screw is way too long and requires grinding on your air plenum to make it fit. Not a replacement part as BBK claims. I went with the Holley and am pleased that it fits without grinding on anything. Badman
Old Nov 21, 2006 | 03:56 PM
Engine: 305 tpi
no i dont i have STANDARD fuel pressure regulator since i get it cheap because i work for NAPA :-)
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
