what do I need to move if i buy SLP intake?
Old Dec 18, 2006 | 08:40 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
I'm interested in getting the SLP cold air intake for my 1991 Trans am. My battery is on the driver's side. Will I need to relocate anything? I've heard part of the fuel system and the battery may need to be moved. What parts do I need to relocate?
Thanks!
Bill
Old Dec 18, 2006 | 09:16 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
what intake are you getting? My "stock intake set up" was on the passenger side. All i had to do was....well was supposed to move the charcoal canister. But I just tossed it in the trash. I bought the SLP cold air induction summit part # SLE-21000. But I got it cheaper because they price match.
Old Dec 19, 2006 | 07:46 AM
wgripp's Avatar
I ended up ordering SLE-21010 (I think) from Summit racing last night. I heard I need to move my fuel vapor canister. What the heck does this thing do anyway?
Thanks!
Bill
Old Dec 19, 2006 | 07:57 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
it cleans up all your unburned fuel. I plugged my lines, cut my wires and taped it up. Now you can't even tell I was suppost to have one.
Old Dec 19, 2006 | 07:59 AM
wgripp's Avatar
I'm guessing that if I remove it, my emissions are gonna hurt. I live in NJ, and they have a smog test.
In order to use the kit, did you need to cut a hole in the side of your engine bay? I honestly can't run out and look at my car right now (because it's in the shop). Is the material you need to cut through steel or plastic?
Old Dec 19, 2006 | 08:53 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Yes, you are correct. Then you have to re route it to the drivers side, and tuck it down next to your battery. You need to buy longer vaccume hose, and some wire to make the wires reach. The auto parts store sell the vaccume hose connectors, so you can hook up 2 hoses together.
No, once you remove the charcoal canister, it bolts right to the opening on your fender well. I might be able to get a pic of mine. or maybe you can see it in one of the pics in my Vbgarage.
Old Dec 19, 2006 | 09:21 AM
wgripp's Avatar
So to use the SLP intake I need to buy vacum hose and wires for the fuel canister?
How much do I need?
According to the online instructions at SLP's site (which don't include the 90-92 version since they don't sell it anymore), it comes with some wiring and tubing. Maybe I need more?
http://www.slponline.com/inst/21006.pdf
http://www.slponline.com/inst/21010.pdf
Turns out I found the instructions for the 90-92 version. According to this there should be some tubing and wiring. Do I need more?
Old Dec 19, 2006 | 09:47 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
well your going to have to route it and see. You want it to look good. I would also get some wire ties. That way you done have wires and vaccume hoses hanging all over the place. I think if I remember right, they give dont give you enough, and they want you to go infront of the motor with all the wires and hoses. I would reroute everything along the firewall to make it look good.
Old Dec 19, 2006 | 11:23 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I bought the SLP kit years ago and it came with everything needed.
Old Dec 19, 2006 | 11:30 AM
wgripp's Avatar
Thanks again guys!
Like I said, I cant run out to the store right now. How many wires do I need? 1? 2? What size vaccum tube is required? Is one brand of vaccum tube better than another?
Anything else that needs to be extended or rerouted besides one vaccum tube and some wiring?
Old Dec 21, 2006 | 10:14 PM
WinnipegGTA's Avatar
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
I wish they still made the dual intake one, for the 90-92's. Id snap one up like that. Hell id even buy a used one if those even existed.
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
AkDrifted
Aug 17, 2015 07:45 PM
