is this going to work
Old Dec 26, 2006 | 03:43 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
so i'm putting an '86 tpi setup on my '89 lo3 but i'm worried about if my speedometer is going to work or not, the '89 has the electronic speedo but the '86's had mechanical speedometers right? is this going to work?
Old Dec 26, 2006 | 05:24 PM
Vader's Avatar
"86 Pontiacs have a VSS on the transmisison and an electronic speedometer. Where you might encounter a problem is in the signal buffer, since the '86 used an optical VSS and the '89 MAY have used the tachogenerator type VSS. The output rates may be different.
Old Dec 26, 2006 | 06:27 PM
Ughh61's Avatar
9900950 VSS/TCC 4000 pulse generator
http://www.compperformancegroupstore...&Category_Code=
just connect to cable and you have 4k pulse for speedo
Old Dec 26, 2006 | 06:32 PM
Ughh61's Avatar
correct me if im wrong
BUT dont 86 use the 2kpulse*
Old Dec 26, 2006 | 10:44 PM
johnnyboy's Avatar
i forgot to mention that the ecm i have is from an '89 so if there is a connector on the harness far a vss, and the connector is the same between years than i probably won't have a problem right?
Old Dec 27, 2006 | 07:37 AM
Ughh61's Avatar
sorry i mistook your post as cable to electronic
Old Dec 27, 2006 | 07:51 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
You may have to switch VSS sensors. I know on the 90-92 cars they are the same TBI to TPI but I'm not sure of '89. You might want to check out TPIParts.com, Angel is a great source of info on swapping TPIs, he should be able to get you the answers you're looking for.
Old Dec 27, 2006 | 04:38 PM
johnnyboy's Avatar
yeah i've been asking the guys at tpiparts.net about this stuff and they've been very helpful
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
