high idle ....
Old Dec 28, 2006 | 03:26 PM
1BadaGTA's Avatar
Car: 1991 Gta trans am
Engine: 383ci,trickflow alum. heads, hsr
Transmission: T-56, alumin. driveshaft
Axle/Gears: stock 7.5"/3.42
high idle ....
My car had an high idle before it got really bad it would idle at like 1100 rpms or so and now that I've cleaned out the intake plenm its idle goes up past 2100 rpms at start then goes down to like 1500 rpms. Any ideas why? I've checked the vac lines and the one on the throttle is cracked but I don't think it would cause it to idle this bad.
Old Dec 28, 2006 | 04:40 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
I have the same problem but it idles at like 1,300 which is still ridiculous. I have heard of dirty throttle bodies, and maybe a tps sensor being the cause but i would like to get down to the bottom of it. On mine i dont about yours but when i put it in Drive it goes back down to a manageable idle.
Old Dec 28, 2006 | 06:06 PM
1BadaGTA's Avatar
Yeh mine is really weird because it used to idle alittle lower than yours even after the t-56 swap but now after I cleaned the intake all out it went even higher and I can't figure it out and its worse on my car because I've got almost 200,000 miles on a stock motor and I need it to last a few more months before I get the new motor.
Old Dec 28, 2006 | 08:42 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
Did you clean the IAC? If no do a search on
1...cleaning IAC sensor
2...seting min. idle air
3...seting TPS
Old Dec 30, 2006 | 01:13 AM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
mine did that to, had to get the computer reset
Old Dec 30, 2006 | 01:23 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Sounds alot like a vacuum leak.......
Double check your work thouroughly.
Might have put the gaskets on the wrong sides of the plenum or not hooked up a vacuum line.
later
Jeremy
Old Dec 31, 2006 | 03:53 PM
1BadaGTA's Avatar
How did you get it reset?
Old Jan 1, 2007 | 05:11 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
I fought this exact same problem in my car years ago. It dident matter if it was hot, cold, first start or anything. Sometimes it worked fine, then it would act up. After checking everything five or six times, I ended up having to replace the PCM itself. After I got the new computer, never happened again.
Old Jan 1, 2007 | 10:51 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
yes i want to know how you reset the computer too. Just disconnect the battery? or some other method?
Old Jan 2, 2007 | 12:17 AM
dave-92gta's Avatar
naw, i had to take it to a shop. i tryed the battery thing, but that only clears codes on the chack engine light. they ahd to re-install the stock information on my rom, or computer or w/e.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
