88 GTA 305 Starting / running issues.
Old Jan 1, 2007 | 03:58 PM
Purple 92 SS's Avatar
Car: 1992 Z/28, 2000 SS, 1968 RS/SS
Engine: 355 Built a bit / LS1
Transmission: T-5 / A4
Axle/Gears: 4.10 / 2/73's
All,
I tried a search, but for some reson searching is not working for me.
My buddy has an 88 GTA 5.0TPI, and as he was driving today, waiting at a light, the car shut off totally and would not restart. It had been running fine for over a year. So we pushed it into a parking lot and tried to troubleshoot it. We found that the car was apparently not getting any spark. It turns over and over fine, I tried starter fluid... didnt start. I treid taking the plug out of the motor, and grounding it to see of any sparking, didnt see any. We then replaced the coil, and still no spark.
Any help on getting this issue resolved would be great, as we hav eno clue what could be causing it to not run at this time, and it is his only form of transportation.
Thanks in advance.
-Steve
Old Jan 2, 2007 | 04:29 PM
bump...
anyone at all???
Old Jan 3, 2007 | 11:19 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
maybe the brain of the car needs replacing.
Old Jan 3, 2007 | 11:33 AM
Tubbed's Avatar
Check the wiring at the coil and distributer for any cuts. maybe not getting proper current.
Start the process of elimination.
Old Jan 3, 2007 | 02:39 PM
the day of the issue, we checked the wiring as best as we could.l Couldnt find any issues at the time.. all wireing looked good.
I dont think that a wire shorted would make the car just shut off randomly all of a sudden, and keep it from running.. which is what happened essentially.
I thought maybe the computer gone bad.. but i dunno. It just seems wierd that he'd be driving and running at a light, then all of a sudden have nothing.. ya know?
Old Jan 7, 2007 | 08:15 PM
87turboGN's Avatar
ignition module
Old Jan 7, 2007 | 10:03 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Originally Posted by 87turboGN
ignition module
/agree
Just replace it, Cant hurt
Its the module under the distributor that sends a signal to have spark More or less, When they get hot/old they tend to fail
Old Jan 8, 2007 | 10:09 AM
well we tried a new computer from a buddys car it ran, but not well..
replaced ignition module as stated by 87TurboGN and it ran fine with origional computer.
Odd how it just all of a sudden went out. Oh well. It works well now though so thats good.
Frozer!!!
Jan 19, 2024 04:55 PM
bryan623
Mar 22, 2021 06:43 PM
justin57
Aug 20, 2015 07:05 PM
86Base
Aug 8, 2015 01:34 PM
