cam questions for 305
Old Feb 1, 2007 | 12:08 AM
Pennocks91ws6's Avatar
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
k, ive started to pull my motor
its my first time, no ones helping (but you guys) and im graduating in a few months.
if i get the zz4 cam, right around 500 lift just over (ill put 550 springs in) can i keep the stock heads? cuz a friend can rebuild them for free and regrind my valves, can i keep stock lifters? maybe rockers?
but what about the valve seats? can i put bigger seats and valves? or do i need to machine things (im in no mood for machining)
i dont want to "choke" my cam or motor, because i know its a fairly hot cam
also, what choices do i have for distibuter? i cannot find one anywhere for a t.p.i with the electrical adavance ( i think my original is bunged) and what about the distributer gear? bronze, copper, titanium, mercury WTF.. i just wanna drive it! i thought chevys were easy
Old Feb 1, 2007 | 02:53 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Well I dont know alot of the questions but I'll do the best I can.
Yes you can use your stock heads.
Yes - you can use your stock lifters.
Yes - you can use your stock rockers.
If you can get your heads redone for free.....go for it. Can I send you my heads to get redone for free too? LOL!!
Old Feb 1, 2007 | 07:24 PM
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Transmission: 5 spd.
Axle/Gears: 3:42s
Well, do you think that hot of a cam is a good choice? I mean stock heads, intake, runners, exhaust, not to mention your chip for your tune-up. Just a few things to think about.... Maybe I'm too old fashioned. Good luck!!
Old Feb 1, 2007 | 07:45 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Im putting an LT1 cam in my 305 (well, its already in)
Ive changed my valve springs, kept my stock lifters, rockers, pushrods, valves, etc.
I have ported my plenum, and base, changed ignition cables, and other little things.
Im praying there is no problems and it will run sunday night.
Cam: .450/.460 lift 202/208@ 50 110sep
Sheldon
Old Feb 1, 2007 | 08:36 PM
Car: 91 formula ws6
so lt1 will be a big improvement fro mthe 305s? would i have to change springs too!
btw my exhaust will consists of headers..... dumped
so dont worry about my exhaust
lt1 would require a little filing on the stub pin right?
Last edited by Pennocks91ws6; Feb 1, 2007 at 08:38 PM. Reason: Automerged Doublepost
Old Feb 1, 2007 | 10:32 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I put in a xr258hr cam in on the same heads(LB9)
206/212
.480/.487
110 lsa
Then I put 1.6 roller rockers on, but I had to put on stiffer springs.
It worked really well, too bad I blew the motor before I could put L98 aluminum's on
Old Feb 2, 2007 | 07:32 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Yes, the LT1 cam would be a big improvement over your stock cam.
305 cam: lift: .350/.350 Duration 202 / 206 @ 50
LT1 Cam: .450/.460 Duration: 202 / 202 @ 50
If you add in some 1.6 rockers, your at .480/.491
If you choose to add the 1.6 rockers, then yes you should change your valve springs. I am staying with the stock rockers, but i am changing the valve springs because my stock ones have 145k and their due.
Yes, you would need to file down the end stub, no big deal
I am also adding a set of Edelbrock TES headers, ill let you know sunday night how it all turns out.
Sheldon
Old Feb 2, 2007 | 09:04 AM
Car: 91 formula ws6
Sheldon
Thanks man!
but if i use 1.6's,, will i have any promlems with spring bindings,or pushrod garbage? i plan on using the old z28 style springs, damenpener on the inside, and hold up to 550.
I think im going with the lt1 then, i had no idea she was that ronchy,,,
good luck with the header isntall, does it come with the y pipe? ive been looking into those..
Old Feb 2, 2007 | 09:10 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
I bought my headers used w/o the y-pipe for $75, ill be fabing up my own y-pipe, so that sould be interesting
I have an extra LT1 cam avaliable to me for $30cdn.
Feel free to add me to msn or aim.
Hope im being helpful
Sheldon
Old Feb 2, 2007 | 09:48 AM
Car: 91 formula ws6
k, i cant overstiffen my springs tho right,, like 550s wont be too stiff for them. i think
im very interested in cam,, used? new? known milage?
stock t.p.i should hold up cam right? till i can get a stealth ram (and 1.6's)
any chip suggestions? i sont want to buy all the chip burning stuff yet (im no tuner)
any problems with this distrib? liftetime warrenty,, and its clear, cant get no better in my books.
http://cgi.ebay.ca/TPI-FIREBIRD-CAMA...QQcmdZViewItem
thanks
Old Feb 2, 2007 | 10:23 AM
Drac0nic's Avatar
Hey, if you have someone doing a valve job and are going to cam up, do a bit of porting. It's probably not going to be the end all of mods but at the same time you've got the heads off and if you nick a set it's not a big deal. It's also more a function of time then anything. If he can get the valves back cut, it wasn't in the budget for me otherwise I would have. http://triodes.home.mchsi.com/engine/v8astro4.html
On the distributor a reman is not too expensive, what's wrong with yours? You can replace the pick up and maybe even get the bushings.
Old Feb 2, 2007 | 10:29 AM
Car: 91 formula ws6
i think my distrib is bunked,, either the electric advance, or vacum or gear,, i dunno its a stock p.o.s with 212 000 kms
Old Feb 2, 2007 | 10:50 AM
Drac0nic's Avatar
If you're running a stock style distributor it has no vacuum or mechanical advance, the ECM controls it. As long as the shaft is tight in side to side play and the gear isn't chewed I wouldn't sweat it personally, new distributor cap, check the reluctor and take the module into auto zone or similar and have em check it. I thought that rebuilds were a little over $100 if you wanna get one anyways.
Old Feb 2, 2007 | 11:11 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
I'm running a custom grind Comp Cam with ported stock heads.See sig for details.
Old Feb 2, 2007 | 08:25 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
thanks
Personally dont know much about ignition, i kept my stock distributor, but added an MSD cap and rotor, taylor cable, and iridium plugs. Soon ill add a blaster coil, but i need money for that.
I just bought a brand new set of Comp Cams valve springs today for $75cdn (brand new) The PN is 981-16. Im hoping everything is ok.
Like i said, ill post up sunday night and let you know how it all ends up..or ends
Sheldon
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
