spring question
Old Feb 3, 2007 | 04:30 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
spring question
does anyone know what the maxumum lift the stock valve springs can take?
Old Feb 3, 2007 | 07:50 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
This may help:
Vin 8 and 7, Valve Spring Dimensions
Free Length 1st step 2.03 in
Damper Spring 1.86 in
Installed Height Intake 1.7187 in
Exhaust 1.5937 in
Seated Pressuure 76-84 lbf at 1.7 in
Compression Pressure 194-206 lbf at 1.25 in
I'de say they are good for .470"-.480" lift.
Old Feb 3, 2007 | 08:48 PM
Damon's Avatar
In most cases they'll actually take about .500" becuase they use a rather small diameter wire (ususally more than the stock head itself will take before retainer-to-guide interference happens). Unfortunately, that also means they don't have enough tension to control a performance cam that would lift them anywhere near that high.
Old Feb 4, 2007 | 11:35 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
thanks for all the help, i thought it was somewhere around .480-.5. that will be more than enough for my new cam. its the TPIS flat tappet cam.
@.05 lift 221/230 and .454/.454 lift. it should be a good match for my stock headed motor. that along with my new runners and ported base should make this thing haul aZZ. iam hoping for mid to high 13s, i think she should get there.
Old Feb 4, 2007 | 11:55 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
have you ever heard of anyone haveing problems wiyh a cam that big with the stock springs? by the way their from a 85 L98 there still preaty new so i dont need to replace them if i dont have to. i was also looking at a crane Z cam it has 218/230 and .459/486 lift (both cams have 112lsa) both will give very similar resualts, but i think that the lift on the Z cam maybe too much.
Old Feb 4, 2007 | 11:57 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
most i have head ppl running on stock heads is .480 and i think some one has stated they are using the Lt4 hotcam on stock heads/springs with the 1.5 rockers...which is .492 lift.
i wouldnt recommend that
Old Feb 4, 2007 | 12:20 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
what about the Z cam i talked about in the post above. iam thinking that i should just go with the TPIS cam and keep it safe.
Old Feb 4, 2007 | 05:29 PM
Damon's Avatar
They'll physically take the lift, but valve float can occur at frighteningly low RPMs. Stock springs were barely adequate for the stock cam up to 5000 RPMs.
A set of Comp 981 springs are true drop-in replacements for stock and will control a mild performance cam MUCH better than stock springs will. A set of cheap "Z-28" springs off the internet will work, too, for less money.
Old Feb 4, 2007 | 10:00 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
sweet, thanks for the help. i might get those springs.
Old Feb 4, 2007 | 10:43 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Don't forget the valve seals. Check them for clearance.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
