Fuel Pressure Regulator
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I think maybe I need a new Regulator because I can't hold any fuel pressure.
Can someone tell where the regulator is located? I have a 305 TPI.
Car: 87 Camaro IROC
its at the back of the intake manifold underneith the plenum. follow the fuel rails to the back and it will meet up to a block with a black round top, thats your regulator.
what do you mean when you say you cant hold fuel pressure?
Car: 89 IROC Z28
Engine: 357 TPI
Well, we had a pressure gauge on it and it read 0 psi, We started the car it went to about 40 (fluctuating), but when we turn it off it fell immediately to about 10 psi and then gradually dropped to 0 psi again.
Car: 87 Camaro IROC
it sounds more like a fuel leak more than a regulator problem, 40 PSI is the norm (its actually 42 psi, but those stock ones are so crappy, you get fluctuation and innacurate pressure). mayb one of your injectors has a bad seal, did you do any work to your engine recently?
Car: 89 IROC Z28
Engine: 357 TPI
I had the fuel pump replaced with a Walbro, that's the reason I was thinking maybe the Regulator crapped out because it couldn't take the increased fuel. I'm just crasping at straws right now.
Right now it's at Duyno Don's getting a custom exhaust system and LS1 brakes, but we need to solve this fuel problem first.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Found the problem....the hose they used popped a hole in it.
Car: 89 IROC Z28
Engine: 357 TPI
Don, if you're still monitoring this thread, the hole in the hose explains why I couldn't hold fuel pressure but not why it was hydraulically locked, or the strong smell of fuel.
Just thinking Out Loud.
I concur, but the reason it popped that hose is because of the kink they put in that line. The fumes must be from the vent that is broke.
9192camaro
16
Feb 3, 2019 12:21 AM
