Which rockers for AFR 180's/ZZ4/219
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I was thinking crane gold 1.6rr. Would you guys stick with 1.5's or go with the 1.6's? I have the upgraded springs on my heads that will handle up to .600 lift.
Will
Will
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
hey whats up man.
what cam are you goin with? ZZ4 or the LPE 219 cam?
either of those cams with 1.6 rockers will be well below .600 lift. AFR's like to flow at that high lift...so i would look into 1.6 rockers.
sorry, its the zz4 ho shortblock, lpe 219 cam. Thanks
Will
Will
Yeah I have the 1.530 springs for .600 lift. Does that affect which rockers I get? I will look into those pro magnum 1.6's.
Will
Will
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I've seen too many aluminum ones fail from varius posts and online searches. + It seem everbody in the magazines are usng the promags as well
I'm using these narrow body with my Eliminator 180s and XFI268 cam. No problems with vavle cover clearance.
http://store.summitracing.com/partde...6&autoview=sku
I am leaning towards the Pro Mags at this point. I like the anodized look, but no one is goingt o be able to see the pretty colors under a valve cover. Might as well get the no nonsense ones instead.
Also can someone explain self aligning and non self aligning to me? Should I go with one or the other? Thanks
Will
Will
I realize that. But the 219 is a great cam, regardless of whether or not is might be outdated. Guys still make a lot of power with them. And the 180's tend to favor a nice single pattern cam. It's a good matchup in my book.
Will
Will
88SS6SPEED
Nov 11, 2015 07:05 AM
Dragonsys
Sep 25, 2015 03:51 PM
