Removing cruise control have any adverse effects?
Old Feb 8, 2007 | 04:16 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I don't need, don't like looking at it, takes up space, and with the new engine I will never use it. So I wanted to know if I can just plug that vacuum like and remove the diaphram/cable w/o any adverse effects on driveability/vacuum. Thanks
Will
Old Feb 8, 2007 | 04:19 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I've done just that since I can't find a correct length cable for mine since the TPI swap and it runs just fine. Just be sure to keep the line intact to the accumulator or there will be problems.
Old Feb 8, 2007 | 04:21 PM
norcalz28's Avatar
And the accumulator is that orb under the car on the driver's side right? I am ordering a new one since the little vacuum nipple busted off my original
Will
Old Feb 8, 2007 | 04:33 PM
Mongoose's Avatar
Car: 90 Formula
You are correct sir.
Old Feb 8, 2007 | 08:31 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
if you are interested i can point you in the right direction for this cable. PM me if you are interested.
Old Feb 9, 2007 | 08:05 AM
Mongoose's Avatar
Car: 90 Formula
My cruise module was located down by the radiator as it was originally a TBI car. Since I swapped to TPI the module would need to be moved up to the wheel well and I'd rather kep it by the rad. Supposedly the TPI cars only came this way but I have seen an '88 IROC with it in the same spot as mine and with a cable connecting it to the throttle so I know it's out there, I just haven't found it yet so until I do it sits on the shelf. The TBI cruise cable is too long BTW.
Old Feb 9, 2007 | 08:37 AM
Boosted_SS's Avatar
Engine: 383 TPI
i did the same and i have the cable on my car. if you're interested i can help you find it.
Old Feb 9, 2007 | 08:53 AM
Mongoose's Avatar
Car: 90 Formula
Where?
Old Feb 9, 2007 | 07:16 PM
Boosted_SS's Avatar
Engine: 383 TPI
go to www.hotrodlane.cc and get their number and call them. if they don't have the part they will almost certainly be able to give you the part number for GM and you can get it from a dealership. i know i got everything through them but i can't remember if i got the cable from the dealership or from them but they will be able to help you without a doubt!
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Street Lethal
Aug 12, 2015 11:33 AM
Bull86
Aug 10, 2015 05:43 PM
