Self Aligning? HELP!!!
Old Feb 11, 2007 | 01:47 AM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
I am getting a set of 1.6 RR, however I am not sure if they are self aligning or not. How do I tell if they are self aligning? What can I do to make them work if they are not? BTW I have a 91 stock l98. Any help in advance is greatly appreciated.
Old Feb 11, 2007 | 08:18 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
the area around the roller tip should come farther down then the tip itself.
if not bring them back or you could drill and tap for screw in studs and use some guide plates.
Old Feb 11, 2007 | 08:55 AM
Skoda101's Avatar
Car: 1987 GTA
Engine: High reving 332ci monster
Axle/Gears: 3.73 posi
self aligning roller rockers have a guide or flange you could call it at teh tip were as non aligning rockers have none
I've attached images to show aligning and non(well trying anways ) gold ones are the non aligning and the blue ones are
Old Feb 11, 2007 | 08:57 AM
Skoda101's Avatar
Car: 1987 GTA
the yellow ons have been changed to organe because the image was to big notise the silver roller at the end has no guide or flange
Old Feb 11, 2007 | 10:56 AM
firstfirebird's Avatar
Hey, brian. Unless you know your heads, it's hard to say without looking. Non-self aligning rockers have guideplates that are basically a flat piece of metal with two "u's" ground in them to hold the pushrods vertical.
I haven't taken the valve covers off a SBC 3rd gen yet, do you have to remove the upper or middle to get the covers off (we have to on the V6)?
If not, just pull the covers and look real quick.
Old Feb 11, 2007 | 11:00 AM
EDIT: Did you already but them? If so please show us...
Old Feb 11, 2007 | 02:44 PM
Thanks john. I believe I can just take them off. I have however found out that they are non self aligning. They are actually on ebay. Cheap ones, however only temporary. Maybe you could help me install when I get them. should be in like two weeks.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=120084935550&ssPageName=STRK:MEBI:IT&ih=002
oh yeah, from what i read in other posts, I do need 3/8" self-aligning ones but I could use the non self aligning ones if I got some guide plates.
Old Feb 11, 2007 | 03:18 PM
And new studs drilled/tapped
Old Feb 11, 2007 | 03:24 PM
That sounds pretty hard
Old Feb 11, 2007 | 04:28 PM
Better off finding self-aligners. If you need to get those or alredy have them, I can help you chang to non's but it is a pain.
Old Feb 11, 2007 | 07:59 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
self aligning is ok on a stock motor. however if you are building for power i would switch to guide plates. also make sure you get the slimmer body rockers for the center bolt valve covers or you'll be screwed!
Old Feb 11, 2007 | 11:52 PM
carguy502's Avatar
Car: 1969 Nova
Engine: LT4 Hot Cam L98
Axle/Gears: 3.42 8.5" 10 bolt
I heard that if you go to 1.6 RR that you have to do a little clearencing where the pushrod passes through the head. Is there any truth to this. Also, does anyone have any brand or fitment reccomendations? I have Comp Pro-Magnums on by big block and they work like a charm, but these aluminum corvette centerbolts seem harder to work with.
Old Feb 12, 2007 | 12:00 AM
Guest
Guest
Posts: n/a
It depends on the head. Some have a narrow slot that serves as a guideplate of sorts and it doesnt leave much space for the 1.6 rockers slightly different geometry. Corvette aluminum heads have a rather large hole where the pushrods are so there's no issue there.
Old Feb 12, 2007 | 02:54 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Louis Tool:
http://competitioncams.carshopinc.co..._id/14515/4710
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
evilstuie
Sep 24, 2015 02:31 AM
89 formula TPI
Sep 20, 2015 10:54 AM
