SLP runner question
Old Feb 11, 2007 | 05:27 PM
graphicideas1's Avatar
SLP runner question
will slp non-cold start runners work on a cold start intake? I current have a 9th injector but it is not doing anything other that pluging the hole. Also is a '89 vett intake the same as a fbody?
Old Feb 11, 2007 | 08:02 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
i'm not sure about your first question but the vette intake should be the same as the Camaro. the only differance i could possibly think of would be the EGR valve location. i think some came out near the rear of the intake.
Old Feb 12, 2007 | 02:38 PM
why would the egr be in a different location? would it make a difference installing it in a f body?
Old Feb 12, 2007 | 02:49 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
IIRC, Corvette EGR valves were bolted to the exhaust manifold instead of being underneath the plenum. There was a pipe that fed exhaust gas from the valve to the rear of the intake manifold. This was because the Corevette aluminum heads didn't have the center exhaust passages cast in them.
I have an old Edelbrock TPI base and it came with a block-off plate for the the Corvette pipe.
Old Feb 12, 2007 | 02:51 PM
so it will not work with stock iron heads???
Old Feb 12, 2007 | 02:54 PM
here is a photo of the intake
Old Feb 13, 2007 | 09:29 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
the edlebrock base has provisions for both EGR locations
Old Feb 13, 2007 | 09:31 AM
Thats great but this is a stock '89 corvette base
Old Feb 13, 2007 | 10:21 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
does the base have the EGR provision in the midle of the intake .... Or is it just at the back passenger side of it ?
tazs2000
Jul 15, 2017 08:44 AM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
redmaroz
Aug 16, 2015 11:40 PM
