fuel setup
Old Feb 12, 2007 | 12:03 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
fuel setup
i am in the last stages of finally getting all the info and getting together all the parts i will need. One of my last questions is that, for all of you that have went away with the stock metal fuel lines to something like braided, i would like to know all that has used the summit or accel adapters on their fuel rail and have run braided line to these. can you put two 90 degree fittings next to each other with out them hitting each other or without having to turn one more and have the line sit on top on the other line. the fittings seem so close to each other that i didnt know if they would fit and some possible ways of doing this. (word file diagram)
Old Feb 13, 2007 | 05:35 PM
79malbiu's Avatar
Anyone ?
I was wondering the same thing
Old Feb 15, 2007 | 04:44 AM
Car: 87 trans am
then again i havent looked at my car in a while, are the fittings on the tpi that screw into the thing that looks like a block just above the water pump, are they sitting next to each other like left to right or are they sitting one on top of the other. (diagram attached)
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
pimp2303
Jul 27, 2017 02:03 PM
gta90
Sep 15, 2015 04:00 PM
Street Lethal
Aug 13, 2015 08:28 PM
