Getting new runners. Few questions
Old Feb 25, 2007 | 03:55 PM
bonz's Avatar
Car: 89 GTA
I will be making a order soon for some more mods and had a question about runners. Since I already have the edelbrock base will i benifit from larger runners like AS&M runners over edelbrocks high flow runners if I dont plan on doing any porting. Thank for the help.
Mods. GMPP Vortec heads, Comp Cams XR269HR, Crane Gold Rockers, Hooker headers, SDPC intake manifold, free flow exhaust, Air Foil, TB Bypass, K&N filter. Future mods, TPIS Runners, AFPR.
Old Feb 25, 2007 | 09:13 PM
Mark 89Formula's Avatar
Yes, you'll benefit from the runners with your heads and cam. Look favorably at the AS&M/TPIS ones over the Edelbrocks.
Old Feb 25, 2007 | 09:55 PM
bonz's Avatar
Car: 89 GTA
I like the stock look of the AS&M over edelbrock but if the gains are going to be simular between both I might end up going with the cheaper edelbrocks.
Old Feb 26, 2007 | 12:32 PM
Take a look at the dyno graphs in this article to get an idea how the different runners compare. I went with AS&M myself. The Edelbrocks will be great if you extrude hone them but out of the box they're not as good as the extruded AL runners (AS&M, TPIS).
https://www.thirdgen.org/forums/tpi/...feb-super.html
Old Feb 26, 2007 | 07:45 PM
Frank 84 Bird's Avatar
Car: 87 Trans Am
Transmission: TKO 600
If you don't want to do any porting I'd go with TPIS or AS&M Runners. I went with Edelbrock runners because I found a new set for $235. I ported them and partially siameesed them. I have a StealthRam now, but I have to go back to a LTR setup to pass smog. So I'll lose hp but gain torque. I'm kind of looking forward not having to rev my engine to 6k rpm.
You should check out the thread in the Group Purchase section about AS&M's customer service. I believe TPIS has them in stock I'd go with them unless you want to wait forever.
Old Feb 26, 2007 | 08:20 PM
bonz's Avatar
Car: 89 GTA
Thanks for the help guys I believe ill be going with the AS&M. Ill see if I can get them through fasttoys performance. I plan on making another order through summit and getting an afpr, sub frame connecters, strut tower brace, 2nd gear servo, still undecided about a tq arm. Plus i need to get it tuned its not running near as fast as it should be.
Old Mar 1, 2007 | 04:47 AM
BADCAM70's Avatar
Car: 89 IrocZ
Engine: 5.7
Transmission: TH700
Axle/Gears: 2.77
I got the SLP siamesed runners have hogged them out as best i could make it,the finish is not that good but they where cheap so they will have to do.
Old Mar 1, 2007 | 09:01 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Originally Posted by bonz
Thanks for the help guys I believe ill be going with the AS&M. Ill see if I can get them through fasttoys performance. .
Somebody just dropped out of the group purchase for the AS&M runners through fasttoys. You should be able to take that person's spot for $350. BUT it's an extremely slow build on AS&M's end. Be prepared to wait. If interested, shoot fasttoys a call and check out the thread in group purchases.
Old Mar 1, 2007 | 09:42 PM
bonz's Avatar
Car: 89 GTA
How long will it be to get the runners if I place an order tomorrow.
Old Mar 2, 2007 | 07:31 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Who knows. If the savings is worth the wait for you.......
Old Mar 4, 2007 | 09:18 AM
rel3rd's Avatar
Car: 1967 Camaro
Engine: 327
Transmission: Turbo 350
Axle/Gears: 308's
There's still 9 people or so that have been waiting since mid-September, so you may want to take that into consideration....
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
