Setting the Timming on a SD TPI
Old Mar 2, 2007 | 03:59 PM
800-HP-305's Avatar
Im looking for some help in how to set the timming on a 92 SD tpi . Im also looking for the right idle speed setting for a 305 TPI ( minmum air setting )
Old Mar 2, 2007 | 11:38 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Base timing is 6*
Make sure you unplug the est wire(it's on the pass fender and it is a brown wire) when you are checking and adjusting the timing.
I ran 15* initial timing but I had alot of mods for a 305.
Start with 6* and go from there.
Do you have any mods?
Idle I think is 750rpm in drive.
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
Fast355
Dec 2, 2016 06:33 PM
TheExaminer
Aug 19, 2015 10:07 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
