Urgent!! High Idle after changing Fuel Injectors
Old Mar 9, 2007 | 05:32 PM
TransAmman87's Avatar
Car: 90 Trans Am
I put new fuel injectors in my 305 TPI bird today, I upgraded to 24# injectors in light of doing some modifications in the near future. I finished everything up and started the car to get the computer adjusted to them. Immediately, the tach jumped to 3000 and stayed there and wouldn't idle down. I pushed the accelerator a tad to see if that had any effect, but it just increased the idle. I have no idea why this is now doing this. I didn't change the gaskets on the runners. I just reused them like I have done in the past. Could this be a problem? This is driving me insane, because this car is my daily driver, I have been without it for 3 weeks due to repair shops not accurately finding what was wrong with it and they finally did, using a flow test, and I set about fixing it.
I know the first thing to look for it a vacuum leak, but so far I haven't found anything... Does anyone have any suggestions or ideas as to what could be causing this?!
Old Mar 9, 2007 | 07:39 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Sounds like a vacuum leak but did you get a recalibraded prom to work with the new size injectors?
Old Mar 9, 2007 | 08:20 PM
Car: 90 Trans Am
Didn't get a new prom for the fact that I have been told that the ecm learning curve can learn to accept the larger injectors. Would a 350 prom do the trick if this is the case?
Old Mar 9, 2007 | 08:21 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You can not simply install 24# injectors in a 305 which had 19s, and expect it to run right. You made a mistake. You should have installed an AFPR instead.
Old Mar 9, 2007 | 09:27 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
You need to get a new prom and replace your runner gaskets..
Old Mar 9, 2007 | 10:23 PM
TON*LOC's Avatar
Car: 1987 firebird trans am
Transmission: 5 speed
Axle/Gears: 4th 10 bolt hope fully it last
I'm not trying to sound like a ****, i really aint. i'm more of a joker. but i'm i the only one reading this thinking DUUUUUUUUUUHHHHHHHH !!!!!
Old Mar 24, 2007 | 07:45 AM
C6matt's Avatar
Car: 05 C6, 91 z28 Vert, 66 Mustang vert
Engine: Ls2, TPI 350, 289 4bbl
Transmission: T-56, T-5, C4
Axle/Gears: 3.42,3.08,3.73
Re: Urgent!! High Idle after changing Fuel Injectors
+1
Old Mar 24, 2007 | 11:12 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
burn a new prom telling the computer the #24 are there and you will be ok.
Old Mar 24, 2007 | 11:37 AM
Guest
Guest
Posts: n/a
Might be the vacuum line for the brake booster was left off.
Old Mar 24, 2007 | 03:25 PM
Car: 90 Trans Am
Got it fixed... I exchanged the Accel injectors for Ford SVO 19# injectors... it was cheaper and it fixed the problem... so I used the left over money to buy other stuff! Thanks everyone.
specialized
Jun 18, 2022 09:26 AM
bryan623
Mar 22, 2021 06:43 PM
jklein337
Sep 19, 2018 06:23 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
