Stock L98 cam upgrade
Old Mar 11, 2007 | 12:12 PM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
i have a rebuilt (1988) l98 (rebuilt to stock) what cam would be good for a stock motor?? What kind of performance gain can i expect?? I dont really plane on doing any other mods, just headers with this motor.
Old Mar 11, 2007 | 12:17 PM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
well you dont want that crazy of a cam, the one i have in my 383 works nice.
212/218 .444/.454 110lsa
thats probably about all you would want to put in your car if you arent doing any other mods besides a full exhaust
Old Mar 11, 2007 | 04:23 PM
FormulaL98's Avatar
who makes that cam?? thanks
Old Mar 11, 2007 | 06:43 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You can search this forum for other suggestions, as this question gets asked a lot.
You are limited by the stock heads and springs to a camshaft with .470" of lift or less. The biggest cam that works is the Crane Compucam 2032. You should replace the valve springs at the same time, as they are almost 20 years old on your car and worn out.
Old Mar 11, 2007 | 08:37 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
my cam is in my Sig. I love the cam for sure.
Old Mar 11, 2007 | 09:03 PM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
Your heads/springs can actually handle around .500" lift or so.
An LT4 Hot Cam with 1.5 RR's would be about as big as you would want to go on your heads. I was in the same situation a few weeks ago... had the motor out and wanted to do a cam swap, so I just put in Scoggin Dickey Z28 Performance Springs with 20k stock lifters and motor runs flawless, and an LT4 Hot Cam will give you a nice little lope!
Old Mar 13, 2007 | 10:11 PM
ajk511's Avatar
Car: 1991 z28
Cam-aro i didnt know you were MECP. me too!! haha, nice to see another installer who actually enjoys a third-gen. anywho, go with the lt4 hotcam. summit has a package that includes everything you need for it. might as well take the heads and get them ported. take the cam and all the new stuff it comes with to the machine shop with you just to make extra sure that your heads turn out perfect for that set up. im waiting for mine to get done at the machine shop right now
Old Mar 13, 2007 | 11:00 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
LT4 will need a tune to run best... but is fairly big for a stock L98 but will work. i'd do springs on that motor and run 1.5 rockers. should give .495 lift.
else a cheap cam upgrade will be the LT1 cam... nice cam for stock TPI cars but still mild.
some of the smaller comp cams XE cams would be nice. xe264 roller would be nice.
ZZ4 is also a nice cheap choice but will need springs to handle the lift.
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
