Manifold vacume at idle
Old 03-12-2007, 04:52 PM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
Transmission: SEMI STOCK 700R4
Axle/Gears: 3.45 9 BOLT
i fixed the rugulator problem somewhat and starts better now but what vacume pressure should i be running at and what is a good idle in neutral ,now i've got 21 in" -Hg of vacume at idle, and i'm running at 875-750 rpm in neutral if i lower the idle rpm the engine hesitates and oil pressure goes down to almost 15psi or red area.
Old 03-12-2007, 08:05 PM
HD4mula's Avatar
Not sure what is the stock reading but 21 sound great to me. I had 18 with my previous non stock cam on stock intake (if that matters) and now have 17 with my XFI268 cam and AFR heads on AS&M/Edelbrock intake.
86CamaroDan
09-29-2015 10:08 PM
IROCtometal
09-20-2015 11:08 PM
db057
09-04-2015 07:57 AM
IROCtometal
09-02-2015 02:01 PM
Dialed_In
08-20-2015 01:45 PM
Quick Reply: Manifold vacume at idle
