TPI Manifold Question
Old Mar 20, 2007 | 06:00 PM
95 4x4's Avatar
Car: 1995 Chevy 4x4
Engine: 355 cu. in. Vortec / TPI / MAF
Axle/Gears: 3.73 Limited Slip
What do you guy's know about the FIRST TPI manifold anybody have experience with this set-up , it sounds like a nice piece ?
Old Mar 20, 2007 | 11:24 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Re: TPI Manifold Question
It is a nice piece.
Do some searching here for First TPI and it should net u some results and some good posts as well.
later
Jeremy
Old Mar 20, 2007 | 11:50 PM
BadSS's Avatar
I know weeding through the search results can take a while when you're new to a board, so here are a few links to get you started with decent info on the FIRST.
https://www.thirdgen.org/forums/tpi/...-manifold.html
https://www.thirdgen.org/forums/alte...n-runners.html
Old Mar 21, 2007 | 12:23 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
Any opinoins on this "First" base intake? I just got my 58mm TB and ordered my AZ. S&M runners. I'd like to appear as stock as possible, but performance will definitely overide that if I can still pass CA. smog. I plan on port matching my plenum also. Also need to do something with the "snorkel" that houses the IROC ail filter. The Pontiacs air filter with the 90 deg elbow have a better flow IMO. I plan on a stroked 350 when finished (and yes, I will have some PROM work to do to clean it up for smog) with heads/cam to match. Any better suggestions are welcome. Daniel U
Old Mar 21, 2007 | 08:52 AM
95 4x4's Avatar
Car: 1995 Chevy 4x4
Thanks for the links , you are right their is alot of weeding out to do .
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
