removing emission stuff for offroad racing. will it affect the computer.
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
I am also currently in the works of removing my ac setup and all the emisson stuff. for off-road racing
will this affect the computer, I do have a custom chip. so I can get it reflashed if i need to. Basically will I run into a bunch of trouble with drivability, and is there any help sites on sugestions on what to do when I remove this stuff. EX: do i remove the canister or just leave it in. What is a good idea to remove and what should I leave alone. thanks guys. I have a 89 TPI camaro 305
will this affect the computer, I do have a custom chip. so I can get it reflashed if i need to. Basically will I run into a bunch of trouble with drivability, and is there any help sites on sugestions on what to do when I remove this stuff. EX: do i remove the canister or just leave it in. What is a good idea to remove and what should I leave alone. thanks guys. I have a 89 TPI camaro 305 Re: removing emission stuff for offroad racing. will it affect the computer.
I removed my air system with no problems. My ac was removed when I got the car. These things and the cat are all I would take off because nothing else is wort while.
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Will removing the A.I.R system and all other emissions affect the idle or performance of the engine or will it help its performance. I have heard both
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
If its properly functioning it shouldn't change your performance for better or worse.
I removed the AIR system solely because it removes clutter (easier to work on the engine) and headers with the AIR system cost more.
Charcoal canister doesn't affect performance.
A stock cat can be removed for a minimal improvement in flow- but don't bother unless you're upgrading all of your exhaust.
Car: 85 Iroc-Z
Can the car still pass an emissions test with all of the emissions off of it?
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
not unless you live in the 51st state in the U.S.A. removing the emission is for offroad use only. hint..hint..
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
Or @ a habibi gas station.... 5 US dollars gets you alot there
NBrehm
Aug 25, 2015 11:49 PM
