Decent TPI combo?
Old Mar 30, 2007 | 12:41 PM
86z28iroc-z's Avatar
Car: 86' Z28 Camaro
Engine: 357 TPI -- Dart Heads -- Voodoo Cam
Transmission: Built 700r4
Axle/Gears: 3.23 Posi
Decent TPI combo?
Called comp cam and they said with these heads
# SB-Chevy S/R Torquer Cast Iron Cylinder Head170cc Intake Ports
# 67cc Combustion Chambers
# 2.020'' Int/1.600'' Exh Valves
# 1.250'' Valve Springs, .560'' Max Lift for Hydraulic Cam
# Assembled, Sold Individually
that this cam would be prefect for what i'm looking for.
# "XFI" 252 Hydraulic Roller CamshaftChevy 262-400ci 1955-98
Lift: .550"/.546" w/1.6 Rockers
Duration: 252°/264°
RPM Range: 1000-5000
Lobe seperation: 113*
Good for 305 or 350 TBI. Excellent off idle performance. Xtreme torque.
What kind of numbers do you think that combo would put out sitting below the stock TPI intake 355 block?
Old Mar 30, 2007 | 09:05 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Decent TPI combo?
I'm not sure on the HP. You might want to investigate what compression ratio you will wind up with the 67cc combustion chambers. Otherwise sounds good to me.
Old Mar 30, 2007 | 11:24 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
sounds like a good combo!
IMissMy86TA
Aug 31, 2015 08:40 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
