whats wrong with my tpi
alright i have a 89 305 tpi that i pulled out of storage after 6 months when i brought it out it was good for an hour and then it would not idle it was running good until u let of the gas it would stall so i thought maybe gas i filled it up and put injector cleaner in and it worked it ran good as new for a week of lots of driving and now all of a sudden its started happening agin i just turned it on and it will not idle it drives normal but it just will not idle any ideas????
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Re: whats wrong with my tpi
had this happen on my 88 trans am 305 5 speed i bumped up the idle a hair or two took care of it.
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
is youre check engine light blinking?
my 89 was sitting for about 4-5 years when i started it , it ran good till it warmed up, then it idled irraticlly sounded liked a cammed up 383, lots of black smoke. i also thought it was bad gas. i ended up being a bad ecm.
evilstuie
Jan 9, 2020 08:29 PM
Sanjay
Aug 12, 2015 03:41 PM
dhonda200
Aug 11, 2015 11:50 PM
