Stalls when given throttle?????
Old Apr 13, 2007 | 10:26 PM
69TPInova's Avatar
I have a 1986 TPI in my 69 nova and got the engine running its idles nicely but when i go to give it throttle the fuel pressure drops to 10 lbs. Any one have any ideas???? i took out the factory sock filter in the tank for less restriction. i have a singal fuel pump inline. and when the car is on the scan tool it says the car is running with 12 volts shouldnt that be around 14? If anyone has ANY suggestions im open for anything at this point..
Old Apr 15, 2007 | 06:56 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Re: Stalls when given throttle?????
what is the preasure at idle without throttle ?
Old Apr 16, 2007 | 01:23 PM
Detroit_Z28's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: TH350
Keep in mind the oil pressure sender has the power to kill the fuel pump, so if there's a loose wire that breaks connection when the motor torques, it could kill the car. Try jumping the fuel pump relay to diagnose what side you have a problem at; pump side or control side. 10 psi seems to indicate the pump shutting off.
DiabloWS6
20
Dec 11, 2015 04:12 PM
customblackbird
Oct 1, 2015 04:30 PM
amcnellis
Sep 16, 2015 04:16 PM
Randomtask2
Sep 7, 2015 05:06 PM
