TPI Starting Problem---HELP
Old Apr 21, 2007 | 06:42 PM
hedgejj's Avatar
Car: 1931 Chevy Sedan
Engine: 1990 5.7L TPI
I have a 1990 TPI 5.7 that was starting fine, and now will not hit a lick...
I have done the following:
checked for spark on both sides-good
checked injectors on both sides with light--good
fuel pressure is at 45psi with ingition on
confirmed timing at (#1 at TDC and distributor is ok) was timed 6 deg, but wanted to confirm
checked plugs-good
changed ecm (122-7730) just in case
no codes but 12--good
held throttle wide open, clear flood mode--didn't start.
went thru swappers guide and all checks out
What am I missing, why won't it fire, i mean i have spark , fuel??
I do smell fuel....
What next??
Old Apr 22, 2007 | 10:14 AM
hedgejj's Avatar
Re: TPI Starting Problem---HELP
does anyone think this could be the ignition control module??
Old Apr 22, 2007 | 10:49 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
just to clear things up- you used a noid light to check the pulse of the injectors and what did you use to check the spark
is it trying to start or just turning over
Old Apr 22, 2007 | 11:38 AM
hedgejj's Avatar
I used a light to check the injectors.
to check the spark, I pulled plugs.
Also checked TPS voltage ~0.52 volts.
It is not trying to start, just turning over,like it is not firing, but spark is present????
Old Apr 22, 2007 | 02:52 PM
hedgejj's Avatar
replaced teh ignition module---didn't work.
it just turns over, and never acts like it is getting spark..
Old Apr 22, 2007 | 03:11 PM
kid camaro's Avatar
Car: 91 z28
Engine: 305 tpi
i had the same prob a few years ago and it turned out to be a bad distributor. i had replaced everything else related with ignition and nothing happened. might wanna try that.
Old Apr 28, 2007 | 09:46 PM
hedgejj's Avatar
Just replaced the dizzy pick up coil and had the ignition module checked.....no luck.
It just turns over and acts like it is not getting spark. pulled plugs, they are wet and sparking, checked the injectors adn they blink with a noid light, I am to the point were it has to be a electrical issue somewhere??? any direction, it went from running to not firing?????
Old Apr 29, 2007 | 05:03 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
when you do hold it to the floor (starting) does it even kick at all ?
Old Apr 30, 2007 | 09:34 AM
hedgejj's Avatar
no it does not fire at all...
Old Apr 30, 2007 | 03:01 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
Mine was doing something like this (it would start and die), and it was the Coolent Temp. Senser, its a long shot I know.
good luck
Caspar
Jun 19, 2016 11:19 PM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
L98GTA87
Aug 5, 2015 11:02 PM
