Timing Gurus - timing tab and lack thereof
Old Apr 23, 2007 | 02:53 PM
Steve89GTA's Avatar
Hi Guys
A buddy and I replaced the timing chain and cover a few years back on my 89 LB9 5speed. The new Mr. Gasket chrome cover didnt' have the timing tab with it hence, I cannot check the timing of my vehicle - yes, it was 9 years ago and we didnt know any better
So the other day I noticed that Mr. Gasket sells timing tabs separately that bolt to the same bolts holding the cover on.
Does anyone know which one I need? 7 inch or 8 inch style and specifically which model? I'm looking at the summit website and they seem to carry a few different ones.
Old Apr 23, 2007 | 05:44 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Timing Gurus - timing tab and lack thereof
I believe our cars came with a 6 3/4" balancer. 7 should work fine. Get whichever you like. Adjustable, in most cases, isn't necessary.
Old Apr 23, 2007 | 08:10 PM
Steve89GTA's Avatar
Thanks! I'll buy the 7"
Can someone tell me which bolts on the cover to utilize when installing the tab?
Old Apr 24, 2007 | 07:47 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Bolts 2 and 3 when counting up from the bottom right.
Old Apr 24, 2007 | 07:58 AM
Steve89GTA's Avatar
Are you sure? I always thought it mounted closer to the top but I'm probably wrong
Old Apr 24, 2007 | 08:06 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Any higher and it'd be behind the water pump.
Old Apr 24, 2007 | 08:11 AM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
Axle/Gears: 3.27 Borg Warner 9bolt
Buy the 7" and it is the second and third bolts on the right hand side from the top. Super easy, I just did that a couple weeks ago only thing I had to remove was the tpi filter cover
Old Apr 24, 2007 | 08:15 AM
Steve89GTA's Avatar
Cool, I didnt' realize there werent any more bolts down there....been a while since we put the cover on. Thanks again!
Old Apr 24, 2007 | 10:50 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The markings on the stock balancer won't work well with a timing pointer in that location.
Old Apr 24, 2007 | 10:52 AM
Steve89GTA's Avatar
interesting...so what do you suggest?
Old Apr 24, 2007 | 10:55 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can use it, but you'll need to find TDC with a piston stop and remark the balancer.
Old Apr 24, 2007 | 10:57 AM
Steve89GTA's Avatar
we took off the balancer when we did the chain. Do you think its possibly not in the correct location? I remember that there was a keyway of sorts for it to slip on insuring that it was in the correct location.
Old Apr 24, 2007 | 12:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
From 1969 to 1985, the timing pointer was at about the 2:30 position, which is the location of the bolt-on timing pointer. Your factory balancer is marked for a timing pointer in the 12:00 position. Your timing will be about 40 degrees off if you try to use the pointer with the existing balancer mark.
Old Apr 24, 2007 | 01:57 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Apeiron, are you sure it was till 1985?? I bought my 84 L69 99% original, and my tab marks 12:00.
Old Apr 24, 2007 | 04:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I could be wrong. It might have been earlier or later, depending on application.
Old Apr 24, 2007 | 04:43 PM
7.0 camaro's Avatar
Car: camaro
Engine: 383
Transmission: 350 turbo
put the timing pointer on there. find top dead center and make your own mark. i use a white out pen. a stock balancer that has any miles on it will be off a little anyway. the rubber gets hard and they slip. it probably wouldn't hurt to get one of those fancy balancers that have all the degrees on them.
Old Apr 24, 2007 | 04:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could also just get a balancer cover that has the correct markings on it to slip over your balancer.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
masonta
Aug 31, 2015 10:14 PM
91REDZ28VERT
Aug 18, 2015 10:16 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
