running rough and pinging
Old Apr 24, 2007 | 10:43 PM
Jackman5003's Avatar
Car: 1984 S-15
Engine: 1988 Iroc-z 305 V8
Transmission: T-5 (5-speed)
the truck runs great in open loop but hit closed(i.e. warmed up) the thing runs pretty crappy at idle and miss' a bit throughout the RPM range. also under high load it pings, pretty bad too. it also has, not a hard start, but more of a hesitation to start when warm. it gets quite annoying after filling up on gas. my brother says this engine should have more power then it does too, even with the automatic cam it has in it...
i brought it into school a couple months ago, they put an ignition scope on it, and they said the dwell timing(when the coil is grounded again) throughout the cylinders was varing between 10 degrees of each other. i didn't quite look at the scope as the teacher who was a GM tech said its probably a worn distributer shaft, pick up, or ignition module. well, i just put a used distributer in it, with no play in the shaft except up and down like all the other GM disributers i've looked at, and a GM ignition module. the base timings at 8 degrees as this is what my brother ran on his thirdgens.
i've put a differant computer, MAF, TPS, ECT, and various other sensors/relays in it. what else could this be? fuel pressures fine, it does drop imidiatly after shut off which i'm going to cheak the CSI for leakage soon but what else? no vaccum leaks or anything.
Old Apr 29, 2007 | 03:28 PM
Car: 1984 S-15
Re: running rough and pinging
anyone?
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
jbd1969
Aug 17, 2015 07:06 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
