TPI Cam help [not sure about advice from comp cams] help me
Old May 1, 2007 | 03:35 PM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
hello
I have heard nothing but excellence from the 268xfi cam. However, it is usually used with 1.6 rockers. That is a problem for me becuase i have 1.5 roler rockers already.
I called Cam help from comp cams and told them i wanted the same numbers as the 268xfi with 1.6 rockers with my 1.5 rockers, so what xfi cam do i need to go with my 1.5s to match the numbers on the 268xfi.
they told me to get the 280xfi for my 1.5s and that will be just like the 268xfi with 1.6.
i do not know much about cams, but im not so sure what they told me is true.
Please help me out, im 16 and this is my first build
Lee
Old May 2, 2007 | 05:26 AM
Blown 346's Avatar
Car: 2000CamaroSS,69 Camaro SS,91 Camaro
Engine: 383
Transmission: TH 400
Axle/Gears: Stock
Re: TPI Cam help [not sure about advice from comp cams] help me
Im not an expert and dont know hte answer to your question but Im sure Comp Cams wont steer you in the wrong direction.
Old May 2, 2007 | 06:02 AM
Car: 1989 IROC-Z
Engine: 346 LS6
well, from the little that i know
summit part number CCA- 07 466 8 and CCA 08 467 8
the 268xfi has a 050 inch lift duration at 218/224
the 280xfi has a 050 inch lift duration at 230/236
this would make the 280 a great deal more "lumpy" than the 268. thses two cams are not really that close. I just cant beleive that this is what they recommended for my situation.
Speed
Old May 2, 2007 | 10:38 AM
Detroit_Z28's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: TH350
Thats a pretty signifiant jump in cam, since 1.6 rockers only have about 6% more lift than 1.5 rockers, I would think the difference would be much smaller than theyre recommending.
Old May 2, 2007 | 11:12 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
The 280xfi has a lot more duration than the 268xfi and will make power at a higher rpm because of it. These two cams are not at all the same. Cam durations change very little when going from/to 1.6 rockers/1.5 rockers. It's lift that will change by using different rockers.
The 280xfi is a very big cam for a tpi engine.
Old May 2, 2007 | 11:42 AM
Guest
Guest
Posts: n/a
I'd go with the 268 and get some rockers. The ramps are already very aggressive, no way you're going to find a cam with more lift at that duration with 1.5 rockers.
Old May 7, 2007 | 11:41 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Get the 268 and keep the 1.5s.
Old May 7, 2007 | 04:13 PM
Car: 1989 IROC-Z
Engine: 346 LS6
will that be enough lift????
that wil give me about 536 on the intake and 531 on the exhaust.
Speed
Old May 8, 2007 | 01:08 AM
Can your heads take advantage of the extra lift? I fell into the more is better thinking awhile back when I bought my rockers, went with 1.7s. They added a rougher idle and zero mph in the 1/4. The XFI were designed to run 1.6s though, so it is a little different. If you have the coin, trade up, but I would try to make it a minimal investment.
Old May 8, 2007 | 10:50 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Want to bet?
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Sanjay
Aug 12, 2015 03:41 PM
